Depends on the output stage or the load????
#2 | |
1. how stable the amplifier is, into capacitive loads 2. if the load is considerably Capacitive Most loads: loudspeakers + loudspeaker cables are Inductive This is why a Zobel Filter ( f.ex: 10ohm + 100nF in series ) is always a good recommendation. To be safe, if somebody some time happens to attach a Capacitive load usually, at least in commercial amplifiers, one ~1 uH inductor is also attached across and in parallel with ~10ohm resistor. See my attachment, of the output of Professor Leach Super Amp. This inductor is many times not needed. Nelson Pass has once told, he almost never have needed to use inductor at output. Regards lineup
lineup |
#3 |
diyAudio Moderator Emeritus
Even if the amp is stable from capacitive load, output inductor provides another advantage. That is to "filter" anything HF garbage from entering to the base of inverting differential.
HF garbage will make intermodulation, even if the amp is stable, it will affect the sound. Output filter will not "allow" this HF garbage entering the feedback system. |
#4 |
the full Thiel network should be fitted every time unless the designer can demonstate to himself that some or all parts can be deleted. In the Leach link r50+c25 can be fitted either before or after the R//L pair.
regards Andrew T. |
#5 |
Amps that have a default resistive character to the output, most often don't need the inductor (but the Yobel is always recomended). Musical Fidelity A1 comes to mind, as well as some Naims - the trick is that there are effectively or literally (Naim!) series resistors in the output so current rise is limited for capacitive load.
#6 | |
He is too clever ( professor ) to do things by chance. Regards to AndrewT lineup
lineup |
#7 |
Hi Lineup and AndrewT!
Zobel circuit can cause ocssialtion! I have experiented this thing. Now, my amp have two zobel circuit which is place into both side of inductor but my out transistors are't violently hot Do a AC sweep simulation by a sofware simulation to view voltage on both side of inductor, I agree with lumanauw. My amp include : inductor is paralell with 1K ohms
Justice for Victims of Agent Orange http://www.petitiononline.com/AOVN/Thank all of you! |
#8 | |
Are you sure Zobel did ... because there are usually other things that cause oscillation My experience is, ONLY this : Zobel can help to make my amplifier stable. Regards lineup
lineup |
#9 |
oh! Leach also said
" On the first amplifier I built, I had these on the circuit board where they caused violent oscillations because the current through R50 and C25 generated positive feedback when it flowed through the circuit board signal ground lead. When the oscillations occurred, the heat sinks would get very hot. Moving R50 and C25 to the loudspeaker output binding posts solved this problem. " http://users.ece.gatech.edu/~mleach/lowtim/output.html
#10 |
adding a Thiel network will cause a damped ripple on test square wave. This is a natural consequence of the inductors and capacitors on the output. IT IS NOT AMPLIFIER OSCILLATION. put the zobel in the wrong place on the PCB and it may contaminate a low signal, thus causing amp-lifier oscillation as Leach has described and many other warn against. The Thiel network can be R+C // {series (load +R//L)} or R//L in series with { R+C}//load, the network behaves in both forms. The component values are different. Thiel considers both forms in his equations. Dr Cherry expands on this to show how to scale the components and how to incorporate the whole family of networks onto the output. attachment of an excel spreadsheet showing the calculation and arrangement of components for the Dr. Cherry treatment of the extended Thiele equations.
regards Andrew T. |
| Source for output air cor output inductor?? | sam9 | Solid State | 7 | 19th January 2004 02:25 AM |
| Page generated in 0.10241 seconds (81.76% PHP - 18.24% MySQL) with 11 queries |
