Old 12th January 2007, 12:29 PM   #1
Default Help! Encoder for DS1802
I've recently built Pedja's DS1802 circuit (http://www.pedjarogic.com/spot/index.html) and I'd like to use a rotary encoder for it. What are the specs that I need?
I'm actually looking at the Grayhill 25LB range, and am a little confused as to which one is suitable...
http://embrace.grayhill.com/embrace/...DF/I-51-52.pdf
I'm guessing I need the 2-bit quadrature one?
Any help would be greatly appreciated. I live in the UK so would like to source something locally if possible.
Cheers!
Old 14th January 2007, 11:17 AM   #2
Anyone? Just give me a clue at least.....please!
Old 14th January 2007, 01:03 PM   #3
Rambi is offline Rambi  Netherlands
Default Re: Help! Encoder for DS1802
Cheers!
Yep, the 2-bit quadrature one would be the start.
But you then still need to decode the outputs into up and down pulses for the DS1802.
If you also want a display for the volume settings etc. then I would use a microcontroller, since you need one anyway for controlling the display (then also use the serial interface for the DS1802, not the up/down one).
Otherwise you could try to find some decoders like the following:
http://www.lsicsi.com/pdfs/digpot7184.pdf
http://www.lsicsi.com/pdfs/LS7183-LS7184.pdf
Seems that in your case the LS7183 is what you need.
Best regards,
Remco
Old 16th January 2007, 12:10 PM   #4
Thanks for your reply Remco,
I'm not too bothered about an LCD for now...just looking for an easy way to control the DS1802 in a rotary fashion. I'm not too keen on using a microcontroller - if I did then I'd go for the PGA2310 chips.
Is it not possible to get some sort of rotary encoder type device that pulses? Surely its quite a simple mechanism?
WTB: DS1802 digital pot or similar Moose Swap Meet 0 8th July 2005 10:11 PM
DS1666 vs. DS1802 dalli Chip Amps 0 10th March 2005 08:05 AM
DS1802 with LM3875 soundNERD Chip Amps 11 26th February 2005 08:10 AM
Controlling TDA7448 with DS1802 Help Wanted abid_rehan Digital Source 2 6th September 2004 04:55 PM
Volume control using a DS1802 rho Solid State 11 2nd December 2003 01:35 PM
Page generated in 0.08617 seconds (79.92% PHP - 20.08% MySQL) with 10 queries
