Setting Offset - Proper setup Setting Offset - Proper setup - Page 2 - diyAudio
Old 12th January 2007, 04:37 AM   #11
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
Default Re: Offset compensation and Adjust
Originally posted by lineup
In your amplifier I would try the more simple method
or something like it.
Like is shown in my Attachment.
lineup
I dont really have a choice. this is a Classe amplifier i am repairing. not a new design.
Zc
Old 12th January 2007, 07:50 AM   #12
you do the set up @ operating temperature.
However, it is worth checking what happens to both output offset and Iq as the temperature changes from start up to final operating temperature.
As an example, you may find that offset varies from 30mV cold to -20mV warm. You can move the warm setting to 0mV but the cold value will increase to about 50mV. A good compromise might be 40mV cold to -10mV warm and most of the time during warm up it is in the range +-10mV. This setting will vary a little with the seasons (even in centrally heated homes the summer temps exceed the winter temps).
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 13th January 2007, 02:32 PM   #13
KISS is offline KISS  United States
ilimzm:
Note the service notes for the amp in question generally recommend monitoring the bias regulator first before actually setting the actual value of the bias current. Their test points are referenced to ground where I tend to monitor the difference.
Setting Offset - Proper setupHide this!Advertise here!
Looking for proper transformer. contaxchen Parts 0 15th September 2004 02:38 AM
Proper Grounding Scheme PaulHilgeman Parts 38 14th October 2003 05:00 PM
The importance of proper setup and vibrations control Peter Daniel Everything Else 253 6th October 2003 03:57 AM
DC offset / Bias setting for Aleph 2 fcel Pass Labs 24 26th August 2002 05:29 AM
Copyright ©1999-2017 diyAudio
