I measured 80VDC on the main caps, the service manual says it shut be 60VDC
My unit is a 220V PA-7E version. So a little bit higher then 60VDC I wood expect but 80VDC ? Can someone thell me if the Voltage I measured is ok or much to high. There is no option to set the Transformer for 240VAC. Thanks |
#2 |
80V sounds about right, maybe a bit high.
The 60V sounds like a misprint.
Candidates for the Darwin Award should not read this author. |
#3 |
the transformer secondary voltage is probably around 60 VAC.
Ret. USAF... AKA- Avionic *** Solder slinger for hire...*** |
#4 |
Audio Junkie
What are the PSU caps rated at? that should tell you if your voltage is close to being correct.
If they are rated at 75v then 60vdc should be about right. if they are rate at 100V then 80v would be about right from what i have seen in most major MFG amplifiers. Zc |
#5 |
It's a 200W amp, 60V is not enough no load voltage.
#6 |
Audio Junkie
yeah if i remember right it was 225w @ 8, i used to have a 7 long ago. 80V sounds about right. The Halfer DH-500 were 80v and my soundcraftsmens are 205@8 and those run 70V rails. My classe is 175w and it uses 63V rails so it really should be 80v rails for 225W
#7 |
60 vac x 1.414 = 84.84 - rectifier voltage drop - winding resistance - capacitor esr,etc. = roughly 80 vdc.....
#8 |
My DH500s are all 93V, the Soundcraftsman ran on a regulated 67V.
#9 | |
Audio Junkie
boy it has been so long since i have had my hands in a 500 i just dont remember, you may be right, i remmeber it was high. But i have rebuilt at least a dozen Soundcraftsmen PCR-800, 840, 860, Pro-power, 450x2, and DJ-900 amps and they all ran +/-70 The scmatics i have show 70 as well. ![]() granted were only talking 3v |
#10 |
Thanks for the schematic. Although I have repaired several of these, I have never had a schematic of one.
You're right of course, a couple of volts won't make that much of a difference. I just wanted to make the point that the regulation allows them to start out with a lower voltage than normal and still produce full power out.
| Nakamichi faceplate button interface to main unit: resistor ladder? | whiterabbit | Car Audio | 1 | 3rd March 2009 08:55 PM |
| Amplifier main capacitor replacement - voltage question | Tino | Pass Labs | 22 | 12th November 2008 05:27 PM |
| Voltage readings on Bal Line stage Main Board | Zapped | Pass Labs | 6 | 25th July 2005 07:42 PM |
| Power Supply Main Components Group Buy | DSchmidt | Group Buys | 5 | 5th December 2004 12:52 AM |
| Balanced linestage power supply and main board. | Tony D. | Swap Meet | 1 | 14th October 2002 05:48 PM |
| Page generated in 0.11155 seconds (74.56% PHP - 25.44% MySQL) with 10 queries |
