#21 |
wow , negromo really gives that old NAD amp overkill
(Mj15003/4) They can do 200w+ !! the old NAD will last till doomsday. (with a 2 ohm load) |
#22 |
Jajj ... my friend Ostripper, I cant find originals 2955/3055 anywere, all are fakes (chinesse) that blows @ 5 % volumen. Thats why I put that powerfull original Motorolla pair. And with very good result, I always use the NAD near 80 , 90 % of power and all I have to worry about is to keep the unit aireated.
Sorry about my english. Peace. |
#23 |
FAKE 2955/3055 ? Wow, that's normally what they try and sell as MJ15003/4 and other higher power motorolas!
#24 |
Hey, great thread... just acquired and old 701 (guess they are all old). Fired it up and the outputs are driving speaker loads ok. If one of you has that pdf manual, I'd appreciate a copy, as I'm going to give it a good going over before putting it into service.
#25 |
#26 |
Excellent! thanks very much.
#27 | |
I accept the point of the early 2N3055s (used them but did not realise the R of the emitter lead). But how many knew this? I must first ask whether the transistors Q408, Q411, Q413, Q416, Q417 (and perhaps also diode D406) were all mounted on the heat-sink. If so, thermal runaway could have been controlled by thermal feedback without said emitter resistors. I omit such emitter resistors in a full complimentary topology for another reason, and find that I can easily keep current in the output transistors constant simply by thermal feedback and correct compensator transistor (Q408) circuit resistance values. In fact one can over-compensate by the wrong resistors. |
#28 |
My first post to this forum.
I have a used NAD701 when power up, there is a soft "pop" sound heard from the speakers, is it normal? A meter on the spk terminal shows a low voltage swing from pos to neg and back to zero. When can I do? I am surprise that the Amp do not have speaker protaction relay for the OCL output! Anyway it has been operation for more than ten years before pass it to me so I guess NAD must has good design. |
#29 | ||
I agree that theoretically, thermal feedback can work. In reality, component variations and thermal lag make it very difficult. See the thread on the OnSemi ThermalTrak parts. Quote:
| Any comments on this design? | icebear | Tubes / Valves | 23 | 19th May 2009 04:07 PM |
| My first amp design - comments | blueskynis | Solid State | 36 | 26th March 2008 03:38 PM |
| need comments on amp design | metebalci | Tubes / Valves | 0 | 10th September 2006 08:03 PM |
| comments on this design.. | GeirW | Tubes / Valves | 6 | 13th February 2004 08:24 AM |
| Comments on this design? | G | Tubes / Valves | 0 | 16th October 2003 05:09 PM |
| Page generated in 0.10261 seconds (81.35% PHP - 18.65% MySQL) with 11 queries |
