What is the significant differences among these bias network:
1)single transistor+resistors,very very popular; 2)single transistor+resistors+diodes,something like the Leach amp; 3)two transistors+resistors,usually NPN + PNP,claimed that produce lower AC resistance. ???????? |
#2 |
i've seen the 2 transistor one, not sure if there is any advantage to it, "speed" is not an issue for a bias network.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ |
#3 |
I have seen the multi transistor type and they are often promoted by designers that put low distortion above all else. I think the main route for audio signals from the VAS to load is the capacitor between the collectors (if active load) rather than through the Vbe multiplier. I believe a good cap here is better value than extra transistors.
regards Andrew T. |
#4 | |
Hi Piercarlo |
#5 | |
if this capacitor across the Vbe multiplier transistor can lower distortion. The result that I have found so far: In some circuits it will definitively lower distortion figures. In other amp circuits they do almost no difference. A funny thing about a capacitor before the output stage I found the other day. See my attachment! First I tried with a cap across the Vbe transistor - the common way. Then I tried with putting this capacitor between the BASE of npn/pnp output pair. This is after the base stoppers resistors. Voila! This was the best solution in this circuit. Lowered the distortion by considerable figures. I guess it has to do with pulling out current from the bases. Like is found at several other investigation, by other known amplifier designers. lineup
lineup |
#6 |
Leolabs;
You forgot: 4) multiple diodes+resistor lineup; I also have good experience with this cap placement
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#7 | |
http://www.diyaudio.com/forums/attac...amp=1168269380 |
#8 |
#9 |
roender;
Agree
#10 | |
I know you have good experience, ACD as can be seen in your website: Audio Circuit Denmark lineup - en del are blåe and gule, andre are vide and roede
lineup |
| Changing grid leak bias preamp to cathode bias | bereanbill | Tubes / Valves | 8 | 28th March 2009 05:26 PM |
| Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 | awedio | Tubes / Valves | 2 | 19th April 2008 01:30 AM |
| Battery grid bias to fixed bias in Toccato? | w00t | Tubes / Valves | 3 | 2nd December 2007 12:34 AM |
| Supressed bias amplifier, automatic variable bias system. | destroyer X | Solid State | 2 | 20th September 2004 10:24 AM |
| Home Theater Combo - choices choices | smithsonga | Multi-Way | 1 | 2nd April 2003 05:11 AM |
| Page generated in 0.10026 seconds (84.20% PHP - 15.80% MySQL) with 11 queries |
