#21 | ||
Hi Shawn,
http://www.diyaudio.com/forums/showt...77#post1096777 Quote:
I have not seen on this forum anyone using this part, so I'm kinda out on a limb here. Regardless of the tiny operating current, I like it and haven't found any real drawbacks in performance or sound. In fact the sound is excellent if used properly. The drawback is in the fact that there is a wide % variance in Vgs on these, at least much more than the j201's I measured. Went through 100 or so in the first measurement run. Measured typical Vgs@100uA of around -0.160V to -0.300V for the KSK595. First I measure each device and sort them as similar groups of 10-20% or so. When I need a MP, I re-measure from a group to chose the closest two. Once you have them sorted into groups, it isn't so hard to find many matched pairs. In this circuit, there is about 5V Vds on each input transistor and on each cascoding pair. 5 pairs total...one could grow old looking through a pile of 100 jfets just to find matches. I use these cheap storage boxes to keep them sorted. When I need more MP's, I now have a narrower margin to look through. (The top row is some 5087 BJT's sorted by Hfe)
All the trouble I've ever been in started out as fun...... |
#22 | |
Well, honestly I do my best making a design as Hfe-independent as possible, but that's probably not the answer you expect. I tend to measure output devices hfe to check if they are genuine. As far as diff and vas stages are concerned hfe of more than 100 is OK for me, same for drivers and predrivers of output buffer. |
#23 | |||
Shawn. |
#24 |
Hi Cbs,
your Vgs measurement set-up shows the DMM connected to the FET gate. Is there a chance of causing oscillation doing this? Since there is no current through the 100r could the DMM be connected to pin 6 instead? Thus avoiding risk of oscillation.
regards Andrew T. |
#25 |
Hi Andrew T
Not sure, but you did point out a mistake in drawing. The DMM was measured across the 1K resistor on pin 6. Didn't notice that
#26 |
Shawn,
I think getting yourself a good used curve tracer might be the better route if you're really serious about this. You have measured HFE... but at what operating current? The curve tracer will measure all that at what ever given operating current you want up to device destruction Mark
KSA-100 WIKI |
#27 | |
Thanks, Shawn. |
#28 |
Now yer cookin! I may try one of those out myself. Ita alot lighter than the old tektronix is.
Mark
KSA-100 WIKI |
#29 | |
Screen capture/print and share + easy for achiving. You can't beat it unless you have mucho $$$ to spend. I'm sold... I got to have one! Shawn. |
#30 |
One thing which is adressed in 'curve tracing' in this topic is that hfe is not constant in relation to Ic.
With a multimeter only a small Ic is used to measure Ib and thus hfe can be calculated. When matching small signal devices there is not a huge miss. When matching output devices the intended Ic should be used. I did match 100 MJE15003 and found there was a + and - 2 % spread between measurements with Ic of .7 A and an Ic of .9 A. The average Hfe for .7A was 65.2 and for an Ic of .9 it was 64.7. The hfe from the datasheet for this device was hfe min 25 and hfe max 150.
J-amp powers Avantgarde-Acoustic Trio |
| Need of matching transistors & advanced circuits | fotios | Solid State | 1 | 12th May 2007 02:08 PM |
| Matching transistors for electret microphone? | cafh | Everything Else | 3 | 12th April 2007 11:16 AM |
| Matching Transistors | Vivek | Solid State | 4 | 3rd February 2004 04:38 AM |
| Matching output transistors | hifileslie | Solid State | 1 | 20th May 2002 11:48 AM |
| Page generated in 0.12535 seconds (82.73% PHP - 17.27% MySQL) with 11 queries |
