#2 | |
and PNP and NPN transistors are not made in the same way. So they are always different in several parameters. If this circuit performs better than our known and less complicated ones, then good! At least this one may have some ideas we could take, and make something better out of. I have stated, I like to see peole who can THINK OUT OF THE BOX. I never use cascading. I always try for other solutions, like find transistors that operates better without cascade. Why use 2 transistors, to do a 1 transistor job ?????? I can see this one circuit, in my opinion, is a bit sensitive to supply noise. Which is almost the same as low PSRR (Power Supply Rejection Ratio ). ------------------------------------------------------------- Questions: Is this in use in any Amplifier? If so, what was the result? Regards lineup
lineup |
#3 |
Hi
There is something I fail to understand: basically, the circuit is made of two differential amplifiers, but with complementary transistors in a series configuration, instead of the usual identical transistors in parallel. The inverting input is at the bases of Q7/11, and the non-inverting at the bases of Q10/9. But for the amplifier to operate correctly, the NI input has to be kept at the ground potential; here the only coupling to the ground is via the bias resistors R34/35, and is quite loose. Is this intentional? If not, the open loop gain of the circuit could be greatly improved by substituting two capacitors (or two strings of diodes) to the ground in place of C8. LV |
#4 | |
But I am sure in this case the feedback is for an inverting operation. This makes input impedance 4.7K and R32 / C12 is the feedback. The input will create voltage/current changes in R26 and R27. These resistors R26/R27 are connected to a defined operation voltage by the divider R34, R36, R35 which is between V+ and V-. So this would work. But question is how good? V+ and V- should be at very precise voltages. This is why I wonder about the PSRR of this circuit. I would say we need very good regulated supply for this amplifier. But let's hear from some other people here .. Regards lineup
lineup |
#5 | |
I would separate the bases of Q7 and Q11 and apply feedback to base of Q7. |
#6 |
The potentials of the bases Q8+Q9 and Q10+Q12 are NOT fixed to the ground to avoid flowing currents thru signal ground. So, in this design there is no smallsignal ground at all
There is only 1 powerground node on amplifier`s pcb. Because of this you can`t do mistake when you would route pcb`s traces About "poor PSRR": are they? It`s not poorer than traditional diff+va design. |
#7 | ||
There are plenty of others around, that can't comment on topic subject, but only post about all us non-english spelling mistakes. you are nott the only one, I am afraidly you are nott. So how much better would anyone reader get my message if I is spellingly one letters vrongg? You tell me, QSerraTico_Tico This is what I said: I never use cascading. I always try for other solutions, like find transistors that operates better without cascade. Why use 2 transistors, to do a 1 transistor job ?????? And when did I say anyone should do things my way? What would I be able to do to stop them from Kaskading transistors when there are good alternatives to keep stages simple. There are benefits with KASckading, but there are also several drawerbacks. This you would know, too. So to avoid these drawbacks I will live with a more Cleene And Shimply cirrkut. I understand that you are a kaskading man This is why you feelt I was critisissing jou. But I did not critisise nobody. Why should I? If they want to kassekuding everything, so let them ... I only told my opinion, how I do things and I asked: Why use 2 transistors to do a 1 transistar's jobb? Quote:
Maybe it would work, but this would make a different circuit. And some of the point with this new idea would be lost. Can ask the question in this way: If it is better to separate Q7 and Q11 why did not this IvanGrig do this .... If it is performing better. Regards lineup
lineup |
#8 |
Technically lineup; the term cascading is used for several stages of gain while cascoding is.... you know.
The latter helps reducing the Miller effect as well as the Early Effect. With JFETs as inputs it reduces also the Gate's leakeage current. |
#9 | |
This is crucial, input stage of inverting amp must be high in PSRR. The circuit needs redesigning the voltage references. |
#10 | |
Having the ground node at such an inconvenient place is certainly not an advantage: it means for instance you've to take your input ground from there; it also means there will be unwanted feedback paths via the supply leads impedances: when high currents are drawn, parasitic voltages will appear on the NI input. If you're not convinced, try to include realistic impedances for each of your wires in your simulation: 0.1ohm/0.5µH for example. Also, have you tried to calculate your PSRR? It's easy: R34 and R35 having equal values, it is 6dB seen from the input, but this is then amplified by the non-inverting gain of the amplifier, 22.3 in this case; this means a resulting PSRR of 6-27=-21dB!! (yes, minus!). LV |
| Monlithic transistor IC for input stage design? | Bitrex | Solid State | 16 | 24th June 2009 02:23 AM |
| Unusual speaker cabinet design | Dr.EM | Multi-Way | 18 | 15th January 2009 04:27 PM |
| help me design an input stage for 6b4G PP | AudioGeek | Tubes / Valves | 11 | 2nd September 2005 08:48 AM |
| input switching design for balanced line stage | ijomojo | Pass Labs | 3 | 23rd January 2005 03:02 PM |
| LM6171 input stage design | capslock | Solid State | 17 | 20th March 2002 04:49 PM |
| Page generated in 0.16694 seconds (78.79% PHP - 21.21% MySQL) with 11 queries |
