Old 9th January 2007, 08:35 AM   #1
Default calculationg a heatsink for bjt's
can somebody help me how to find the heatsink for more than one bjt. ex if I have two bjt that will need to be fixed to a heatsink, what type of heatsing will I need to use please ? are there any calculators, not to find the heat dissipation capability of the heatsink but how much heat dissipate the bjt so I can find a heatsink for them.
thanks
ron
Old 9th January 2007, 08:48 AM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Well, we must of course know what those BJT's do. Are they in an amp? If so, supply voltage? Bias current? Load impedance?
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 9th January 2007, 08:53 AM   #3
is there any calculators that I insert the values and gives me an output ?
Old 9th January 2007, 09:12 AM   #4
janneman's Avatar
Yes, of course. You need to find the Vce times Ic at no signal, to find the idle disspation. Do this per transistor on the heatsink, and add it up. That is the MINIMUM you need to be able to dissipate.
Then, you need to decide what the average signal-related dissipation will be. That's a bit of guess work. Generally, music requires a long-term average of anything between 1 Watt and 15 Watt, depending on the speakers. Pick a number, say 10W to be safe, and calculate the Vce and IC resulting from an output power of 10W in your load impedance (8 or 4 ohms or whatever). Calculate the total disspation of the transistors on the heatsink.
Add the two numbers together. This is not strictly correct but errs on the plus side for some more safety margin.
Does this help?
Jan Didden
Old 9th January 2007, 11:33 AM   #5
Default Re: calculationg a heatsink for bjt's
thanks
ron
If I well understand your question: you wish to find how much more heat dissipate a couple of power device on the same heatsink?
In the case of two devices: you halve the junction-case thermal resistance and the insulator thermal resistance and add this "equivalent thermal resistance" to the heatsink thermal resistance (which is the same as before) and, after subtracting from max junction temperature allowed (usually 200 °C for metal packages or 150 °C for plastic packages) the maximum ambient temperature expected (wich is not so easy to define: the "ambient" temperature is not your room temperature but the temperature inside or near the enclosure of your equipment!) and calculate (divide the temperature span by the the thermal resistance obtained before).
Piercarlo
Heatsink... Lewis Moon Chip Amps 8 26th November 2008 07:22 PM
Which heatsink? wxn Chip Amps 2 10th April 2005 01:43 PM
Page generated in 0.08675 seconds (73.28% PHP - 26.72% MySQL) with 10 queries
