Old 5th January 2007, 05:29 PM   #1
ROBSCIX is offline ROBSCIX  Canada
Default Passive EMI shielding?
Hello, If I had a small circuit I would like to shield from EMI, what could I use to do this? I don;t want some $100 solution. Thx for the info guys.
Old 6th January 2007, 03:41 AM   #2
XEAGLEKEEPER's Avatar
A earth grounded copper mesh or sheet around the circuit.should do the trick
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 6th January 2007, 04:01 AM   #3
unclejed613's Avatar
if you need a small shielded box, you could make it out of unetched pc board material, and solder the edges together....
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 6th January 2007, 04:40 PM   #4
Somebody was telling me that anti-static bag-the type you get components and PC cards in would work but I am not sure. Any opinions on that?
Old 6th January 2007, 08:56 PM   #5
tvi is offline tvi  Australia
tvi's Avatar
anti-static bag?
Try sticking your mobile phone in one and watch the signal strengh meter, then ground the bag an see what happens.
James
Old 6th January 2007, 09:13 PM   #6
What are you getting at that the gnd is the key to any sheilding? well I guess it would be. Thx
Shielding? ROBSCIX Analog Line Level 7 27th October 2006 05:28 PM
Passive Crossover for Passive Subwoofer? Toast_Master Subwoofers 23 30th April 2006 12:14 AM
Shielding KornChild5 Everything Else 0 3rd May 2005 06:37 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
RFI/EMI Shielding, is it necessary? mkruger Parts 1 22nd April 2004 05:54 AM
Page generated in 0.07417 seconds (70.72% PHP - 29.28% MySQL) with 10 queries
