I found a PCB layout by r!sc! for ESP P3A in this forum.
http://www.diyaudio.com/forums/showt...227#post735227 Thanks a lot for the posting. I built some chip amps and they work good. And this is my first try of solid state amp DIY. I'm doing with universal PCBs. I made 1 channel and tested with +12V, -12V rails. - Output offset DC is about 50mV. - Both MJ15024 and 15025 are just a little warm. - I set the bias current around 75mA(by setting the voltage drop across the two 0.33 ohm resistors is about 50mV). - +V and -V are about +15V and -15V - Sounds good. No problem until now with that channel. I made one more channel and have some problems. - Output offset DC is about -3.4V. - MJ15024 is getting hot in a few minutes. But 15025 is cold. - I cannot set the voltage drop across the two 0.33 ohm resistors below 240mV with the VR. - +V and -V are about +15V and -14V - Sounds not bad. No hum. I checked over and over and rechecked. And I cannot find any problems like short circuits, open circuits. Could you please give me some ideas or locate the point for solving this problems? |
#2 |
I got pictures of the 2 channels.
This is the channel of no problem(1/2). |
#3 |
This is the channel of no problem(2/2).
#4 |
This is the channel with problems I mentioned(1/2).
#5 |
This is the channel with problems I mentioned(2/2).
I made this channel with the mirrored layout. So, you can see the change of direction with BC546s and BD140. Instead of changing directions, I changed some wiring paths for MJE15032, MJE15033. |
#6 |
In the picture, right channel is with no problem.
Left channel is with problems. |
#7 |
Hello
A good design is the Nashville NA 2200 power amp. Itīs work with a +20/-20 V to +65/-65 V. In the past, I built the ESP amp but itīs donīt work. Sandro |
#8 |
It works just fine when built correctly.
The non-working amplifier is probably oscillating. You need to keep the wires to the output transistors as short as you can. The P3A uses a CFP output stage which will oscillate if not used carefully. Why did you mirror the layout ? Isn't it possible that you have made an error when doing this ? Why not build your second channel as an exact copy of the working one ? |
#9 |
If a pcb is mirrored, then the 3 lead devices called transistors will have to be corrected while assembling
or u will have to buy the mirror copy of the transistor LOL!!! Gajanan phadte |
#10 |
After inspecting the voltages of all the points
and changing the parts one by one, I found that Q1(bc546a) has some problem. By changing Q1, all the problems had gone. So, I think that mirroring the layout gives no problem. Output Offset V = about 10mV Bias Current = set around 70mA I'm testing and enjoying the 2 channels now. Thank you so much. |
| GFA-565 problems | ben62670 | Solid State | 5 | 14th August 2008 06:36 AM |
| HK AVR 335 Problems | utjay2008 | Solid State | 0 | 21st October 2007 02:26 AM |
| Sub Amp Problems Thanks! | crippledchicken | Solid State | 2 | 10th January 2007 06:17 PM |
| JLH problems | serosmaness | Solid State | 11 | 2nd November 2004 06:17 PM |
| RFI problems | laz | Solid State | 3 | 21st February 2004 07:06 AM |
| Page generated in 0.11270 seconds (82.14% PHP - 17.86% MySQL) with 11 queries |
