Old 5th January 2007, 03:02 PM   #1
b0nk3rs is offline b0nk3rs  Philippines
Unhappy Need help with this preamp circuit
I need help with this circuit:
http://www.generalguitargadgets.com/...cticemaneq.gif
I'm a bit new with electronics... I want to know how I could put a buffer before the 1uF capacitor on the top left of the circuit where I'm planning to place the "Line In" provision. Also,I would like to ask where the Power supply should be connected and where would the output be? Thanks a lot!
Old 5th January 2007, 05:09 PM   #2
edl is offline edl  Hungary
edl's Avatar
Check it:
http://sziget.mine.nu/~danko/kapcsrajzok/3cheq.html
Old 5th January 2007, 06:20 PM   #3
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: Need help with this preamp circuit
Originally posted by edl
Check it:
TL071, TL072, TL074
can work good in these filter and Tone Control circuits.
For possibly a bit better sound performance
( if you need highest quality.. instead of lowest cost )
Then try Replace with
OPA134, OPA2134, OPA4134
Like TL074, OPA4134 is 4 opamps in same IC.
OPAx134 and TL07x are both JFET transistor input Operational Amplifiers.
So they are good replace.
If you are happy with normal good audio quality, then you should stay with TL074.
The are considerably lower in price!
And if you upgrade to OPAx134,
I can NOT Promise you will notice in difference in Sound Quality.
.... this is how small improvement will be
.... it is up to you, if you think it is worth the money
Most would stick with TL071, TL072 or TL074 and get good results.
lineup
information for compare:
TL071 TL072 TL074 - datasheet PDF
OPA134 OPA2134 OPA4134 - datasheet PDF
lineup
Old 14th January 2007, 03:03 PM   #4
could I increase the values of the caps by 5%? I'm having trouble finding capacitor values ranging from nano farads below... should i also change the values of the resistors and pots?
Old 14th January 2007, 05:31 PM   #5
unclejed613's Avatar
try .05uf (actually .047uf), .022uf, and .0047uf since these are the same cap values, just expressed in uf rather than nf. some manufacturers still "skip" the nf range in their catalogs (not that it's not there, it's just expressed in uf)
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 14th January 2007, 06:09 PM   #6
sixtek's Avatar
Yes.
As here: http://users.otenet.gr/~athsam/3_band_eq.htm
Old 15th January 2007, 03:52 AM   #7
thanh is offline thanh  Viet Nam
thanh's Avatar
Send a message via Yahoo to thanh
Hi !
I'm trying to improve my pre-amp. Schematics at this thread are inverting-converter. Is is better than non-inverting-converter ?
Thanks!
Justice for Victims of Agent Orange
http://www.petitiononline.com/AOVN/Thank all of you!
Old 15th January 2007, 07:53 AM   #8
lineup's Avatar
Originally posted by thanh
Hi !
Thanks!
I terms of quality there is almost never any difference.
Between inverting and non-inverting use of op-amps.
The only reason inverting input is used, when mixing, adding several signals
is that this is more simple circuit to do.
This is for example when mixing several microphones recordings, into one.
The drawback is, that you may need or want to invert back again
in some later stage.
If you are just building a normal line preamp,
with one signal input at the time
( even when you can select one of 5 different sources, with for example rotary switch )
I would suggest a non-inverting set up.
This way you will keep your signal in phase = normal, non-inverted.
lineup
lineup
Old 16th January 2007, 04:18 AM   #9
thanh's Avatar
Thank Lineup very much!
Old 16th January 2007, 05:55 AM   #10
lineup's Avatar
Thanks, thanh
I guess you now about Rod Elliott ESP projects.
He has got several good preamplifiers using Op-Amps.
Project88 is well known at this forum.
Also he has got other preamps, with or without Tone Controls.
Most of us do not use tone controls (if we want hifi we may not want to 'change the sound').
Here is list of all different preamps projects.
I think lower numbers are older projects.
http://sound.westhost.com/projects-2.htm
Here is the SiteMap of ESP.
It is one of the best places for us DIY-ers
http://sound.westhost.com/site-map.htm
Also articles, guides & tutorials, like:
Opamps 1 Designing With Opamps I - What they are, what they do, and how they do it
Opamps 2 Designing With Opamps II - Audio applications, filters, crossovers, etc.
Opamps 3 Designing With Opamps III - More Filters, Specifications, Comparators, etc.
Enjoy
lineup
lineup
Bass Preamp Circuit?? anybody?? Zero Cool Instruments and Amps 18 8th December 2010 06:08 AM
Mic Preamp, need circuit Dioda Everything Else 0 1st May 2006 07:03 AM
Need Opamp Mic Preamp Circuit JojoD818 Solid State 15 2nd August 2003 04:15 AM
Zen preamp circuit Helix Pass Labs 1 7th January 2002 02:51 PM
Preamp Circuit cm961 Everything Else 9 15th June 2001 02:12 AM
Page generated in 0.13244 seconds (82.23% PHP - 17.77% MySQL) with 10 queries
