Jung's line drvr, use parallel AD811's?
Old 4th January 2007, 05:47 AM   #1
redrabbit is offline redrabbit  Isle of Man
redrabbit's Avatar
Default Jung's line drvr, use parallel AD811's?
background:
In Jung's "Composite Current Boosted Line Driver II"....
(page 22)
http://waltjung.org/PDFs/ADI_2002_Se..._Drivers_I.pdf
......uses a single AD811 as a buffer-in-a-opamp-loop(per channel) to boost current, which will drive +100 ohm headphones.
_____
question:
Can I parallel more 811's, for more output current?...to drive 32ohm headphones.
=RR=
Old 14th February 2007, 01:20 PM   #2
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I cobbled together this -- the idea for the AD811 surfaced in the 2003 remake of the Adcom GFP565 preamplifier from AudioXpress -- the AD826 dual VFB opamp (contrast with the CFB AD811) is supposedly very well matched and seemed, at least from the figures in Walt Jung's "OpAmp Applications Handbook" to offer a couple of gnat-whiskers better performance -- this replaces the opampcumbuffer in the GFP-565.
needless to say, I am going to burn some boards this morning and check it out -- it's mostly surface mount, save for the RN55D resistors. I have a vintage preamp with a socketed LM301 which I will try it out on:
Old 18th February 2007, 09:23 PM   #3
redrabbit's Avatar
Alrighty.
I migh have those parts too.
I'm a point-to-point only guy, but I might give it a go, if you get good results.
Thx.
=RR=
Old 18th February 2007, 10:45 PM   #4
jcx is offline jcx  United States
AD811 isn't particularly magical to my knowledge, so many substitue options are available today - with greater output current so that paralleling isn't necessary
as long as the output amp is faster than the input op amp the frequency compensation isn't too difficult
I have used the 1A output current LT1210 in a multiloop similar to this, with the TO-220 packaged 1210 in point-to-point on a gnd plane + plated through hole prototyping pcb
in smt there are many high speed DSL driver options with >300mA output rating - LT1795, AD8397, TPA6120
Old 19th February 2007, 04:52 AM   #5
vynuhl.addict is offline vynuhl.addict  Canada
vynuhl.addict's Avatar
The ad744/ad811 combo sounds killer!. I use this combo at the output of my pre-amp in a gain of 3 and it would take a very well worked out discreet design to better sonically and especially considering with the dc offset as low as 1/10th of a millivolt you can eliminate ac output coupling and use it dc coupled. Just dont turn on your power amp first..
Colin.
Old 19th February 2007, 08:09 AM   #6
Default AD815...
http://www.analog.com/en/prod/0,,759_786_AD815,00.html
The ad815 is a dual op amp capable of up to 500ma output current, need good heatsinking or it will get very hot...
Colin
Old 19th February 2007, 08:23 AM   #7
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Default Re: Jung's line drvr, use parallel AD811's?
Originally posted by redrabbit
background:
(page 22)
_____
question:
=RR=
Have you done any calculations about how much current you really need? (not much ). The TPA6120 is rather capable with extremely low distortion values.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 41 pcb's in interest.
Old 19th February 2007, 01:39 PM   #8
jackinnj's Avatar
I forgot about the TPA6120 -- I have a pair of these somewhere -- on both National and TexInstr websites there are guidelines for babysitting the thermal properties of these devices --
Old 19th February 2007, 02:18 PM   #9
bear is offline bear
expert in tautology
bear's Avatar
Question funny ideas in my head?
Ok, so I am an idiot and have soft gummy brain tissue... and I haven't read the .pdf because I'm impatient, on a dial up and it is still downloading...
But what about taking one of these super composite fedback opamp thingies, and dumping a high current SE class A follower or a PP one at the outpoot and wrapping the feedback around it... to drive those pesky headfunes??
<sound of laughter...?>
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 19th February 2007, 04:49 PM   #10
peranders's Avatar
You must separate the minimum specification and what you actually want to build. A normal opamp can drive a headphone rather good and if you connect them in parallel the result will be even better. The next option is to and a simple output buffer of a BUF634. The next step is some overkill. You could check my designs, from the rather simple one to the real overkill.
Jung's line drvr, use parallel AD811's?Hide this!Advertise here!
Jung/PMA Line-Buffer Onvinyl Solid State 82 2nd July 2010 04:01 PM
Ad811 Vs. Lm7171?? mfahimi Chip Amps 2 9th August 2009 09:32 AM
Purpose of Parallel Capacitor with AD811 I/V circuit? fastcat95 Digital Source 3 9th February 2005 05:09 PM
parallel/series line arrays with fullrange? NullPointerAlex Full Range 4 29th December 2004 08:17 AM
Balanced Line Stage vs. ad811 based preamp audionut Pass Labs 6 3rd March 2002 11:23 PM
