Old 3rd January 2007, 05:34 AM   #1
unclejed613's Avatar
Default discrete op amp
thought some here might find this interesting, has a lot of similarity to a power amp design. original design came from the Apt-Holman preamp, except that the Holman had a fet and a bipolar in the diff amp, but that causes a lot of offset, so i replaced the bipolar with another jfet. also replaced the RIAA network with just a resistor in the feedback loop.
-3db points are 2.5hz and 35khz
distortion: -60db (as-is with no tweaking) mostly even harmonic.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 3rd January 2007, 06:37 AM   #2
try moving C3 from the drain of J1 to the gate of J2.
Does it still work?
Will the hi Freq response change if R13 is reduced substantially?
regards Andrew T.
Old 3rd January 2007, 07:46 AM   #3
Gigapod is offline Gigapod  France
unclejed613:
Nice design, simple to understand.
A few questions:
- Did you just simulate it or have you actually built one?
- Temperature stability? PSRR? Output impedance?
- Why do you think one should/would use a discrete op-amp vs a modern audio opamp (2604, etc)?
Very interesting posting, hope you cna show us a picture soon of the working prototype.
AndrewT:
Can you explain your suggested changes/questions?
Old 3rd January 2007, 07:58 AM   #4
Hi Giga,
moving C3 takes out the Miller compensation and gives NFB over two stages rather than one. The Miller comp cripples the LTP.
I think the rather narrow 35kHz bandwidth is due to the gain being set to near +60db. I suspect that this discrete will never be used like a true opamp and it would be fairer to set the gain (and see the CL BW) to nearer where it will be in practice.
regards Andrew T.
Old 3rd January 2007, 08:09 AM   #5
Tim__x is offline Tim__x  Canada
Your regulators don't regulate any ripple beyond Vbe-Vce(sat).
Your PNP transistors are backwards.
As Andrew said, the gain is unrealistically enormous.
Other than that the design should work, though it is a little lackluster.
Old 3rd January 2007, 11:21 AM   #6
Thanks AndrewT,
I consider your posts some of the best, most informative in this forum.
Keep'em coming!
Old 3rd January 2007, 12:56 PM   #7
Hi Giga,
thanks, but not everyone agrees with you.
regards Andrew T.
Old 3rd January 2007, 02:13 PM   #8
Q5 is backward as shown, and would not function as a current mirror.
art
Old 4th January 2007, 12:51 AM   #9
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Yes,Q5 is a drawing error.
Can the BJTs/FETs be subsituted with Japanese types???
Old 4th January 2007, 03:01 AM   #10
tnx...... it's what i get for working late hours..... q5 and q7 are backwards............. i'll redo it and rerun it.....
actually the circuit in it's original form (with a 2n3904 in place of j2) was a very successful phono preamp in the Apt-Holman preamp
tnx for the heads up out there...... unfortunately sims rarely tell you that you just let the "magic smoke" out of components..... those 2 backwards pnp's definitely would have given a nice smoke and light show.......
My first discrete amp danfo098 Solid State 60 30th July 2009 05:40 AM
Discrete DAC i2s hugobors Digital Source 0 29th March 2007 02:10 PM
Ic Vs Discrete AR1 Parts 4 29th April 2005 02:09 PM
Page generated in 0.09458 seconds (81.39% PHP - 18.61% MySQL) with 11 queries
