Old 1st January 2003, 05:54 PM   #1
Default Weird, Less noise with more voltage.
Hi, all
I'm stitting here with my amp, and playing with different input voltage rails. I've noticed a 25% reduction in output noise levels with a double in rail voltages. ( .0125 vRMS @ +-20 Volts, and .0094 vRMS @ +-50 volts.)
Currently, The higher voltage rails increase the bias currents on diff pair and grounded emitter stages.
This is a subject I've not really encountered before, and was wondering how bias voltages/currents affect noise levels in transistors, or has anyone ever looked into this.
-Dan
Old 1st January 2003, 09:28 PM   #2
halojoy is offline halojoy  Sweden
On Hiatus
Default Re: Weird, Less noise with more voltage.
Originally posted by dkemppai
Hi, all
-Dan
Well, the bias can effect the crossover distortion.
also the current sorces, can make
the input be balanced (equal current in each transistor)
at a certain voltage level.
The difference should be kept as low as within a couple of %
between those 2 transistors! For optimal performance.
A higher voltage gives less of a saturation in some of the transistors.
Can make them behave better. Especially in the voltage amp stage.
At dynamic signals.
This is what I can come to think of.
Surely there must be others, who know much better.
We can wait til Nelson comes back.
I would think he will have a valid opinion.
How do you measure the noise?
It is with no input signal?
How is distortion with sinus signal?
Is it changing with the supply voltage, as well?
/halo - the homemade expert on noise
Old 1st January 2003, 10:01 PM   #3
Default Re: Re: Weird, Less noise with more voltage.
Bias for AB output devices is directly across several diodes. One Zener, and 3 standard diodes. My output devices are mosfet, so voltage needs to be around 6 yo 7 volts or so. Across the diodes, any changes in the bias current has very very little effect on bias voltages. This voltage remains constant even up to 100Khz, at 50W output.
As for the noise, I measure it with my scope. It automatically calculates the RMS of waveforms (And many other measurements). I measure with no input signal, and an 8 ohm load. Absoutley nothing changes except the rail voltages. (I turn the knob on a variac to adjust voltages)
I see no distortion on a sine or triangle waveforms through the entire input voltage range (+- 10 Volts to +-80 volts). I also checked the drive signal to the AB output stange. This is also a very nice clean sine (or triangle) waveform.
Typically, I will see crossover distortion here, when the bias voltage between output devices is too small and the differential pair is compensating.
Now, you have me thinking, I wonder if the zener generates more noise with less bias current? Interesting. But, this seems a little excessive, since the gain of the output stage is 1. The zener would need to make 12mV RMS... ...not sure, but it seems a little much.
I'm going to have to start digging around for sources of noise. The amp is fairly high gain (40dB), so any input noise will be amplified greatly.
Here is a schematic... ....the feedback is not shown, one inverting input stage is also missing.
-Dan
Old 1st January 2003, 10:19 PM   #4
On Hiatus
Default Re: Re: Re: Weird, Less noise with more voltage.
-Dan
Yes, it might be the only. The zener.
I NEVER use Zeners in my audio circuits.
It is well known that they are "noisy".
compared to smallsignal diodes, LEDs and small signal transistors.
There are several better ways to generate constant voltage.
The most used is the common amplified diode
configured low noise transistor.
Sometimes you can improve this amplified diode
by using two transistors. A two stage amplifier.
Especially when the current through the stage changes a lot
from idle value, when the amplifier works with signals.
This is mostly not the case
when MOSFETs are used in the output stage.
I find no need to use zeners, ever. In audio circuits.
I do not understand why this is done?
Maybe you are right, the noise can change to lower,
at a higher current in the zener.
Maybe some reminiscent from "the old days".
/halojoy
Old 2nd January 2003, 12:37 AM   #5
Default Re: Re: Re: Re: Weird, Less noise with more voltage.
/halojoy
I am planning on switching to an amplified diode. The amp is still a pile of wires pushed into a breadboard, and glued onto a heatsink. The amplified diode can also help to give me some thermal stability. I've plotted some them compensation curves for these fets, and will fit the amplified diode to match them. But, I'm not to the point of worrying about that just yet.
Still, I think that ther noise from the zener would only affect bias current, and not the actual output voltage. The noise spectrum shows it's flat from DC on up. I would suspect that the amplifier would respond to low frequency noise in this stage, and try to cancel it. (Maybe not???) I'm thinking that the noise comes from one of the more foreword stages.
The noise is low enough that I cannot hear it until my ear is two inches from the speaker. Even so, really need a good spectrum analyzer, and THD measurement equipment!
-Dan
Old 2nd January 2003, 05:33 AM   #6
The one and only
Nelson Pass's Avatar
You have a cap across the bias circuit, so it's not going to
be the zener unless the cap is small, and even then it's
common mode, so it's still unlikely.
When you can't find the obvious cause for noise that is
supply value related, then it is often oscillation, although
most often the circuit will oscillate when the supply increases.
Old 2nd January 2003, 09:08 AM   #7
Electrons are yellow and more is better!
peranders's Avatar
No contribution to this is that the current generator to the emitter follower (middle, at the top) seem to be a small degree of weird?
You don't have a stable current throught the second high-gain stage. Your idea of "compound transistors" aren't so well tested.
If you have a constant base current to a single transistor you will get a very sensistive stage for voltage variations. You must secure stable operating currents with varying voltage. The power supply rejection (PSSR) for one thing will be low, not good for distortion. Using cascodes is an easy way to create high immunity against varying voltage
The resistor//diode thing is a typical thinking of "large signal" when you should think "small signal". The perpose of the resistor is to insert losses to the resonance circuit (in order to the oscillation). Paralleling a diode is the same as paralleling with a cap, rather good one too. Normal standard is resitor, resistor+ ferrite bead or ferrite bead alone.
/Per-Anders (my first name) or P-A as my friends call me
Tube Buffered Gainclone in work |Thread
Old 2nd January 2003, 09:23 AM   #8
peranders's Avatar
Example of a cascode. The rest can be found here .
Old 2nd January 2003, 12:09 PM   #9
Circlotron's Avatar
Could the open-loop gain increase with higher rail voltages, making the NFB work harder therefore reducing the noise?
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 2nd January 2003, 05:08 PM   #10
peranders,
The circuit in the top circle is a brute force current source using some small signal transistors, and one larger higher power device. The Current is set by beta of the particular output transistor (which can change), and the current from current mirror. (I use that particualr current mirror, because I etched a dozen boards, with leads that plug into my breadboard.)
I'm still thinking of improvements for that particular stage, however, I don't think that it'll be cascode.
As for the bottom circuit, the resistor is there to increse slew rate. The complementary pair if fairly slow otherwise, and a diode may be unable to pull the voltage low enough. (Resistor and capacitor selected to the minimum value needed for stability.
Keep in mind that this amplifier is really designed for high power, and trying to do so with simplicity in mind. Output powers of around 200 to 300 Watts @ 8 ohms are the target.
-Dan
Low Noise 3 Leg Voltage Regulators dsavitsk Parts 2 10th July 2007 02:49 AM
Low noise voltage regs Extreme_Boky Digital Source 3 17th May 2007 05:34 AM
Weird Voltage readings after rectifying superR Chip Amps 13 28th November 2006 09:36 PM
Low voltage noise dual OP Holger Barske Parts 7 24th May 2004 06:57 AM
Low noise voltage references peranders Digital Source 1 27th May 2002 04:13 PM
Copyright ©1999-2013 diyAudio
