Old 31st December 2006, 05:35 AM   #1
thanh is offline thanh  Viet Nam
thanh's Avatar
Send a message via Yahoo to thanh
Talking Hepl me! Nice amp but noisy
Hi !
My amp is quite noisy when
- it is connected to my computer
- computer is operating but there are'n any media software which is playing music
- volume is set at maximium level
If I don't connect my amp to my computer, speaker is silent. I tried to connect the amp to the computer directly but problem is still remains
I don't know where noise come from .
I have no 2SC3281/2SA1302. I'm using 2SA1227/2SC2987 instead of. I don't use C7 and C8 for real circuit but amp still works. Even I use these capacitor, noise still doesn't decrease
I'm using sound card CMI 8738
http://www.cmedia.com.tw/?q=en/pci_audio
Bye!
Justice for Victims of Agent Orange
http://www.petitiononline.com/AOVN/Thank all of you!
Old 31st December 2006, 06:07 AM   #2
Twaksak is offline Twaksak  South Africa
Twaksak's Avatar
Hi Thanh
I experienced the same with my first ever amplifier that I made and ran from my PC soundcard. The problem was that the soundcard output impedance did not match the 22K input of my power amplifier. How I corrected this was to use a preamp between PC soundcard and amplifier input. Maybe this might help for you. I am assuming that the power amplifier plays ok with normal source such as CD etc.
Chris
Old 31st December 2006, 06:17 AM   #3
thanh's Avatar
oh! Really ?
So how ohms is input impedance of your pre-amp ?
When I intend to turn off computer, I see your name.
Thank for replying !
Old 31st December 2006, 06:25 AM   #4
analog_sa's Avatar
Nice amp but noisy
Maybe you should change this to "nice computer but noisy"
Old 31st December 2006, 09:14 AM   #5
If I have understood your description correctly then I agree with Analog,
Nice amp, terrible (is it typical?) soundcard.
What if the soundcard is turn right down? Does that reduce the noise?
Alternatively, attenuate the output of the sound card (which also reduces the noise) and then run the sound card near maximum.
This should improve the signal to noise ratio.
regards Andrew T.
Old 31st December 2006, 02:28 PM   #6
Twaksak's Avatar
Hi Thanh
I don't know the output impedance from my preamp but it surely must be made from Op amps. Look on Rod Elliot esp site for hi fi preamp circuit.
Chris
Old 31st December 2006, 02:58 PM   #7
darkfenriz's Avatar
Mute 'line-in' and 'microphone' at valume settings if you use MSwin.
Old 31st December 2006, 03:45 PM   #8
jaycee is offline jaycee  United Kingdom
The CMI 8738 is a dreadful chip. Good for running computer speakers, but not much else.
Old 31st December 2006, 04:08 PM   #9
thanh
Have you tried an issolation transformer between the computer's
sound card output and your amplifier? I have found this seems to take care of most problems.
The amplifier is a stand alone unit I assume?
Old 31st December 2006, 04:57 PM   #10
i think u could use a filter bettwen the SC out and Amp in, like the monitor and other devices u connect to pc have, to filter that HF noise, just a tought, i never tried that for that use, only in mics that catchs rf noise
Noisy Amp vento Solid State 13 16th January 2009 08:45 PM
Hepl me circuit 6h30 dia thien thai Tubes / Valves 8 2nd December 2008 01:53 PM
plugged in 220v by mistake, hepl pls? goliath6900 Solid State 25 16th October 2007 03:53 PM
hepl finding thread... moray james Subwoofers 0 25th April 2007 06:30 AM
noisy noisy noisy noisy noisy tube dsavitsk Tubes / Valves 50 20th February 2006 04:07 PM
Page generated in 0.09736 seconds (79.25% PHP - 20.75% MySQL) with 11 queries
