Old 30th December 2006, 01:00 PM   #1
Send a message via MSN to aguantesoda
Default Calculation
Hi! I want do to know the power of my amplifier, knowing that the tension is of 25v+25v and RL is 8 ohms.?
hola, quería saber como hago para calcular la potencia de mi amplificador, sabiendo que la tensión es de 25v+25v. y la carga es de 8 ohms?
It is for this amplifier:
Es para este amplificador:
Old 30th December 2006, 03:01 PM   #2
edl is offline edl  Hungary
edl's Avatar
If +/-25V is loaded voltage, then the output power is about 30W RMS on 8 ohm.
If 25V is the idle voltage, then it produces about 20W RMS.
On the margin for that power I would choose something more elegant, maybe an integrated power amplifier.
Old 30th December 2006, 03:03 PM   #3
edl's Avatar
At "integrated power amplifier" I mean chip amplifier.
Old 30th December 2006, 03:06 PM   #4
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: Calculation
Originally posted by aguantesoda
Hi!
knowing that the
Voltage is of 25v+25v and
RL is 8 ohms ?
hola,
For +/-22 Volt peak Max Output ( -3V drop for transistors, and also power supply transformer drop )
FORMULA: P (WATT rms) = ( UxU ) / ( 2xRL )
Watt RMS = 22x22 / 2x8
Watt RMS = 484 / 16
Resultade: 30.25 Watt RMS into 8 Ohm
Answer you get MAX ~30 Watt power / 8 Ohm
(And maybe 40-50 Watt into 4 Ohm speakers )
lineup
Old 30th December 2006, 09:58 PM   #5
edl's Avatar
As I wrote too.
Old 31st December 2006, 09:02 PM   #6
Very good! thanks
crossover calculation conket Multi-Way 3 11th May 2009 10:54 PM
Max SPL calculation? Ignite Multi-Way 17 9th April 2007 08:38 AM
Transformer calculation for GC Ipanema Parts 9 4th April 2006 04:42 PM
volume calculation Pbassred Multi-Way 7 5th June 2005 05:58 PM
VAS current calculation demons_wing Solid State 8 11th May 2004 05:29 PM
Page generated in 0.07823 seconds (74.10% PHP - 25.90% MySQL) with 11 queries
