Old 1st January 2003, 10:19 AM   #1
Default What will happen when my LM3876 chip when too hot?
As title.
I got a big heatsink but I think it doesn't help much, cause I use this small chip to blow a big sub, the heat won't get around the heatsink, all just around the chip. Using small fan does make noise, so what will happen to the chip when it when very hot, any damage?
Old 1st January 2003, 10:38 AM   #2
Warp Engineer
On Holiday
AudioFreak's Avatar
These chips have comprehensive protection circuits built in and unless you wire them incorrectly or use them without any heatsink at all, they are very difficult to kill. Basically what will happen is this:
1) the chip gets hotter
2) the protection circuit limits the power output of the chip which means it will clip earlier
3) the sub's voice coil will heat up from being fed a clipped signal
4) if this goes on long enough the sub will die
5) if the chip gets too hot it will shut off but the sub will probably die 1st.
The simple lesson to learn from all of this is that if you hear distortion, turn the amp down. If you cannot play loud enough without distorting the amp, you need a bigger amp. You can use a couple of these chips in parallel and a servo to stop them fighting each other. You can also wire them in bridge mode to get more power into the load but you'll need quite a few chips.
Old 3rd January 2003, 12:11 PM   #3
How big is the big heatsink you're using? I've got two 3886's plus +/-15V regulators for the xover on a 1.1deg/W heatsink on my current project and it runs plenty cool enough. You really shouldn't need forced cooling for a 3876 even on a sub.
Have you checked with a 'scope to make sure the amp isn't oscillating? That's the only time i've ever had any problems with heat on the 3886.
Actually, what's the impedence of the sub? The 3876 might not be that happy about driving into a 2 ohm load.
LM3876 chip VS transistor 2sc2922 amp space2000 Solid State 1 18th May 2008 02:19 PM
Worst that could happen? Dominick22 Tubes / Valves 5 30th September 2006 02:50 PM
what would happen if... aletheian Tubes / Valves 8 14th September 2005 03:34 AM
What happen with this transistor? lumanauw Solid State 22 19th February 2005 12:41 PM
What happen to my sub! Mikka Multi-Way 22 7th October 2002 01:16 AM
Page generated in 0.07613 seconds (76.52% PHP - 23.48% MySQL) with 10 queries
