Make up a laboratory from scratch.
Old 29th December 2006, 01:06 PM   #21
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
I'm with EC. The only thing I would add are a couple more cheap, (5$) DMMs, not so much for precision measurement but for watching things like PSU rails, things you don't need total accuracy for, but need to see if any gross changes occur under fault conditions or initial testing.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 29th December 2006, 01:49 PM   #22
Gigapod is offline Gigapod  France
I am with EC too, and I agree with pinkmouse about the DMMs, with a small twist: a couple of those analog multimeters you can buy at the supermarket for $5 can come in handy, instead of the DMMs.
Somebody mentionned lots of cables, crocodile clips, etc. I agree with that too.
6 1/2 digit DMMs and Rhode-Schwarz distortion analyzer? Yeah, sure, I think they have these at Harman-Kardon and NAD, Carver must have a few too, plus a few more R&D facilities, but I never even came near one...
I guess it will be a long time before I need 6 1/2 digits resolution for my PS voltage measurements.
A good used scope is around 100 pounds, as EC wrote. Start with that and a good workbench (I assume you already have the multimeter).
Old 29th December 2006, 05:58 PM   #23
rephil is offline rephil  Europe
Hi Stefanoo,
I am with EC too as I did misunderstand your question. I use many plastic boxes containing smaller one, and I label all what I put inside, else I would never find again what I need when needed. I group the boxes in a desk as categories of items : transistors, capacitors, resistors, metallic stuff ...
Look at the workbench of pinkmouse : you want that kind of workbench. Mine is not so beautiful, but it is partly metallic, a diy one. As I did it, I find it very very OK.
Best regards
rephil
Old 29th December 2006, 06:42 PM   #24
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Thats like 5 dmm's LOL..
Old 29th December 2006, 07:10 PM   #25
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
Default integrated test software
i use Audio Test Bench for a lot of different things, including EQ'ing rooms.
http://www.higherfi.com/softwar5.htm
i also find this spectrum analyzer software to be quite useful:
http://www.qsl.net/dl4yhf/
it's intended use is for ham radio DSP, but if you browse the various setup menus, you will find that it can do a whole lot more (it seems like it's an audio engineering lab in a sound card). it has a flow-chart based setup as well, that is simple to use, but very flexible.
also, for design work, i found that the limitations of various SPICE demo programs were too restrictive(even the TI "Tina" SPICE software has low node number limitations, but i use it for small subcircuit design). the SPICE program from Linear Technology, however, has no restrictions, but it does not have a THD calculation (a little math with the spectrum graph is close enough, however). you also might want to use low pass filtering with their simulated sine wave source, since it's odd harmonic content is about -50db. their software is available here:
http://www.linear.com/company/software.jsp
all of these programs are freeware, and very useful to me.
i'm also designing a "front end" to use my sound card as an o-scope and function generator with Audio Test Bench. it will have voltage dividers, so i can use it with signals up to about 300V p-p, and will have an output buffer for the function generator. i will post schematics, layouts, and test results when it's finished.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 29th December 2006, 09:55 PM   #26
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
You really can't have too many meters. You need one (or perhaps two) good ones, and some cheap ones. Moving coil meters react faster than digital and can be useful for warning of impending smoke release.
I've added a picture of my bench. The inverted black guttering (lined with kitchen foil) shields the direct light from the 1.5m fluorescent and gives plenty of diffuse light on the bench surface.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 29th December 2006, 10:12 PM   #27
steenoe is offline steenoe  Denmark
steenoe's Avatar
EC, thats a nice lab, indeed
Yeah, 5 would be nice.
Being in the proces of adjusting an A-X right now, I could easily use 2 more than the 2 I have. Some cheapo's will surely do.
What do you guy's think of the PC based "all in one" systems offered these days? (scope, distortion analyser, sound generator...) Sure would save a lot of space.
Steen
Old 29th December 2006, 11:06 PM   #28
pinkmouse's Avatar
Very nice bench EC. Is that an Alpha 10 I see up there? I have one too, but mine is off the road at the moment with a damaged DAVE module.
Jason, I have two more out of shot.
Old 30th December 2006, 06:34 AM   #29
Banned
Yup always good to have. I bought my Fluke 87 for 35$ fixed it and then sent it off to calibration and its perfect. 35$ for a mint meter works for me :d
the next thing on my bench i want is a dual mode psu with pos neg & gnd so i can work on small low current projects instead of building the psu for it.
Old 30th December 2006, 11:20 AM   #30
steenoe's Avatar
Are these any good for the lab? Seems they do most things and being pretty small they should fit in everywhere.http://www.tiepie.nl/uk/products/Ext...illoscope.html
Steen
Make up a laboratory from scratch.Hide this!Advertise here!
FOSTEX 300 laboratory power amp cybersniper Solid State 30 29th December 2017 09:26 PM
"Lux vita" banished from laboratory jackinnj Everything Else 2 24th October 2006 11:41 PM
Switched mode laboratory powersupply Danko Power Supplies 3 12th November 2005 10:20 PM
For sale: Tenma 72-6610 Laboratory DC Power Supply JAZZ2250 Swap Meet 0 18th September 2003 07:13 AM
