Opamp front end examples
Old 26th December 2006, 11:24 AM   #1
jaycee is offline jaycee  United Kingdom
Default Opamp front end examples
Just bored and pondering over power amps that use opamps in their front end instead of a discrete LTP. Anyone got any links to schematics of other amps like this?
So far, i've looked at the MF B1 and the Arcam DiVA A90 amplifier.
Old 26th December 2006, 12:05 PM   #2
RSK is offline RSK  Malaysia
Default OPA134 front end
Try white noise audio. I have the MOS125 circuits and they sound good.
RSK.
Old 26th December 2006, 12:20 PM   #3
latala is offline latala  United Kingdom
try also bgw /amcron/ phase linear /musical fidelity
thee are loads of them out there!
regards trev
Old 26th December 2006, 03:40 PM   #4
ash_dac is offline ash_dac  United Kingdom
Default Re: Opamp front end examples
Rega Brio thread. But you posted on that thread
http://www.diyaudio.com/forums/showt...448&highlight=
Old 8th February 2007, 11:54 PM   #5
Lenin is offline Lenin  United Kingdom
Default Musical Fidelity Worth a look...
Mmmmm.....
Look at the MF schematics (particularly for the P170, P270, P370, P470). The DO use a LM318 op-amp front ends, but the internal long-tailed pair is disabled, allowing the use of an all discrete version.
Errrr... I guess that is kinda the exact reverse of what you are after (semi-discrete rather than op-amp only front end) but worth a look...
By the way, no-one on this forum has yet been able to work out how to utilise other opamps in that particular MF topology. (Much to my frustration........!)
Old 9th February 2007, 05:30 PM   #6
R.I.P.
the British J.E.Sugden P128 uses 5534 as a times 2 gain stage at the front end. It is outside the global NFB.
http://www.diyaudio.com/forums/showt...687&highlight=
regards Andrew T.
Old 10th February 2007, 12:59 AM   #7
jcx is offline jcx  United States
http://www.qscaudio.com/support/libr...ies/rmx850.pdf
ne5532 and floating ouput supplies
Old 10th February 2007, 01:54 PM   #8
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
The Sumo-9 used two LF353's in the in-amp configuration. Kind of a cute circuit, and the patent's expired.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 10th February 2007, 09:42 PM   #9
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
Opamp front end examples Send a message via MSN to AKN
hi,
Lets not forget Jan Dupont and his "LYNX" poweramp.
http://www.audio-circuit.dk/LYNX_main.html
Further developed into PA-34 II
http://www.delta-audio.com/PA-34A.htm
/ Anders
Old 10th February 2007, 10:18 PM   #10
sixtek is offline sixtek
sixtek's Avatar
Originally posted by 4fun
hi,
Hmmm... These are reminding me the Phase Linear model 300.
The same circuit with modern devices.
Opamp front end examplesHide this!Advertise here!
Power supplies examples maverick_123 Class D 2 20th November 2007 02:08 PM
Regulated Supply Examples Mike, K8LH Chip Amps 4 27th December 2005 11:04 PM
examples of crown BCA topology jez Class D 2 30th September 2005 09:10 AM
Examples of DIY motional feedback? Mr Evil Multi-Way 10 21st November 2004 05:20 PM
Examples of finished 6-ch GC's? faithblinded Chip Amps 5 14th November 2004 08:20 AM
