When someone said that your amp perform not so good when listen to classical music(not so detail,blur up),what is the weakness of the amp and how to improve assume that the amp is a:
1)complementary BJT amp or 2)chipamp like LM3875 GC ????????????? |
#2 |
I can think of many reasons to this problem.....
It may be frequency responce and/or to low slew rate...... Listen to rock music, it can be hard to tell if the guitar should sound slightly distorted or not, however in classic music instruments are rarely played distorted! I have a test cd with all frequencies and many acustic instruments plus live recording of common sounds from the real life (thunder, trains, jetplans etc) which I use together with a few selected music cd's to test performance of my amps
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 |
diyAudio Moderator Emeritus
Like ACD said, it could be many reasons.
You can check the +/- rail supply (relative towards ground). Use osciloscope, in AC mode, to see how it looks like when the amp is playing music in average loudness. |
#4 |
Assume that the power supply section and all layout,wirings are ok,where to start???
#5 | |
then with smaller amp........ frankly-if you are sure that layout is OK (at least with widely common project-amps,so you can compare it with other's xperience ) then problem is most offten in amp-spks-room-listenning habbits........... combination
my Papa is smarter than your Nelson ! tnx to |
#6 |
Hi Leolabs,
Not all amps are created equal, tube or otherwise. So your question is far to general to bring useful answers. I listen to classical with tube and solid state, no problems but they do have different sounds. So, what is the make and model of your SS amp? -Chris |
#7 | |
I looked at your question
A little TIM or a little clipping behavior is desired to get the "detailed" or "fast" effect. An amp with bootstrapped VAS (where the output swing can exceed the rails, ie : making half output stage clipping), can be said have better details. A good designed amp (low thd, no clipping in output stage, input stage can handle all signals without clipping) may sound boring if other gears (signal source, speakers) are in ordinary average quality. |
| How to improve this amp | thermonuclear | Chip Amps | 2 | 13th September 2005 06:38 AM |
| Help to improve my first amplifier | ledinhhuy | Solid State | 8 | 28th March 2005 08:54 AM |
| improve the linearity | E007 | Solid State | 1 | 3rd May 2004 09:23 AM |
| Please,can you improve this amp, let me know how | destroyer X | Solid State | 17 | 25th April 2004 09:45 PM |
| Page generated in 0.11997 seconds (65.09% PHP - 34.91% MySQL) with 10 queries |
