with 2pr counterfeit transistors. Yeah, right....
http://cgi.ebay.com/ws/eBayISAPI.dll...2472&rd=1&rd=1 |
#2 |
What exactly does one do with 500W, considering you can solder with 15W, or do thse people live in the city hall.
#3 |
If you could get it to run on ±47V without blowing up, it might put out 60W/8R per channel. The heatsink looks like a very poor design. No sign of thermal tracking for the bias.
I used to look at junk like this from MK V Audio and wonder why they went to all the trouble to kit up something that had a poor design (at best). Some of the kits from Dick Smith (AU) weren't much better. |
#4 |
Someone is actually going to buy it thinking they are going to have a 500 watt amp. Throw the name gainclown on it and I guess anything will sell.
#5 |
Look! The caps are rated 50V
Probably 500 very small watts? Maybe miniwatts... |
#6 |
I saw an amp marked 1000W PMPO
and in smaller print below 50 + 50W RMS The 1000W PMPO was in a font about 4 times the size of the second. |
#7 |
the 1943/5200 running on low supply rails perform very well. 4pair are capable of 350W into 2r with a load phase angle of 40degrees and yet stay with the DC SOAR 35degC. Increasing the load phase angle to 60degrees just takes the 4pair to the 100mS SOAR. Pulsed operation into 1.2r would just about hit 500W. All this from +-48Vdc. From +-38Vdc (26Vac) well that takes some believing. But if you were talking peak power into 1r2, that needs just 24.5Vpk and even less into 1r0.
regards Andrew T. |
#8 | |
I did a closeup = VERY CLOSE! of one of those 2SC5200 in that 500W + 500W amplifier. From my attached 2SC5200 image some one may be able to see if is a Faked or A good transistor. Regards lineup
lineup |
#9 | |
Shawn. |
#10 | |
Hmmmm, TomWaits .... have photos well, no paticular reason but ... tell me where you have some of those photos
lineup |
| Page generated in 0.13214 seconds (64.84% PHP - 35.16% MySQL) with 10 queries |
