how to determine the pin layout of NPN or PnP? how to determine the pin layout of NPN or PnP? - diyAudio
Old 31st December 2002, 10:19 AM   #1
tone is offline tone
tone's Avatar
Send a message via ICQ to tone
Default how to determine the pin layout of NPN or PnP?
by using multimeter?..
example SGD and BCE.thanks for advice..
why different manufacturer have different pin layout..this is so confusing.. i have brought some transistor but dont know which manufacture.
rgds
tone
Old 31st December 2002, 10:34 AM   #2
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Default one of my favorite tools...
-is this: Peak Atlas
http://www.peakelec.co.uk/atlas.htm
Arne K
Old 31st December 2002, 11:33 AM   #3
OliverD is offline OliverD  Germany
OliverD's Avatar
Easy if your multimeter has a diode tester. A BJT can bee seen as two diodes connected in series with either their cathodes (PNP) or anodes (NPN) tied together at the B (base) pin of your transistor.
Your multimeter will "see" a diode from base to collector and another one from base to emitter, if the polarity is correct.
That way you find out
a) if you have a working BJT
b) whether it is PNP or NPN
c) which of the three pins is B (base)
In case of a power transistor, the C (collector) pin is connected to case.
If you enter the type - as written on the case - into a search engine, you will often find a datasheet or some other site with pin layout and data. Or you can ask here in the forum.
There was a DIY component tester in Elektor magazine some time ago - looked like the one on the picture above. It would also give you hfe and Vbe.
Old 31st December 2002, 01:15 PM   #4
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Default Re: how to determine the pin layout of NPN or PnP?
rgds
tone
I think one easy way is to consult the expertise here or surf to www.questlink.com
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
how to determine the pin layout of NPN or PnP?Hide this!Advertise here!
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 11 12th January 2014 09:01 PM
How to determine if class G/H? tktran303 Solid State 21 4th September 2008 11:48 AM
Help in determine port dimensions shlomid Multi-Way 3 28th September 2007 01:45 AM
How to determine Q from a graph? JoeBob Parts 4 13th November 2004 04:12 AM
How do I determine what this Transformer is? wotan2525 Solid State 5 21st March 2003 05:34 PM
Copyright ©1999-2017 diyAudio
