Balanced stages seem popular these days, so i am tinkering with the idea, but i have not put in any serious calculator time on it yet. i imagine that I am looking for something simple and clean, maybe an opamp differential splitter feeding two BUF634 into an XLR output?? Anyone else toy with the idea?
Heghlu'meH QaQ jajvam! |
#2 |
3 years ago, I designed my pre standard amplifier with both single-ended and balanced outputs supported by BUF634T buffers.
#3 | |
How did the BUF634work out? Are you still using them?
#4 | |
CineMag's CMOB-4 would give you a balanced output without all the ancillary circuitry and they're only about $25 a pop in high nickel. se |
#5 | |
We compared it to transformer output, and prefered the BUF stage. Of course it is not the "true" balanced output, if you short one of the outputs the second does not double. But we compared it sonically, and the BUF beated transformers. Contrary to Steve, I do not like transformers at all. |
#6 | ||
se |
#7 |
Steve,
you would not know them, as they are produced here. Very similar parameters to corresponding Jensen link transformers. I do not remember type numbers, it was 2 years ago. For me, the biggest issues are sensitivity to external magnetic fields (heard), a lot of HF noise (measured, IMHO responsible for worsen sound) and higher LF distortion, possibly LF saturation at high voltage levels. That is why I do not like them. Cheers, Pavel |
#8 |
Hello Mr.PMA,
I have question for you.I want use your buffer in DAC and do little test(measure).And my question is which version is best for you?50 Ohm at output and 50 Ohm in cable too.Or without 50 Ohm in cable.And what this alternation do with sound?I remember you tested this.I hope so... I look on PCB and this I must make alone.And you now why. |
#9 |
You can try 2 versions:
1) R10=50 ohm (serial), R12=50 ohm (terminator) 2) R10=5 ohm (serial), R12=infinity (open end), then gain would be +2 / beware of next stage possible clipping After doing your listening test you can tell me which one you prefer. |
#10 |
I remember this discussion between you and OPA.And I now your choice.There is much difference in sound?And last time you promise new DAC.Which buffer you plan use?I think Mark Levinson use same topology (OPA627+BUF634) and this player is not bad.
Of course I show you my DPS and tell you which output configuration is best for me. thanks |
| Unbalanced to Balanced | mcash257 | Parts | 3 | 14th October 2004 12:03 AM |
| Unbalanced Buffer Linestage | Panelhead | Pass Labs | 14 | 13th April 2003 08:53 PM |
| unbalanced/balanced/unbalanced conversion using transformers | vladimir | Solid State | 10 | 27th February 2003 06:54 PM |
| unbalanced or balanced | theturtle | Everything Else | 4 | 5th January 2003 04:52 PM |
| Zen Balanced Line Stage Balanced vs Unbalanced | macka | Pass Labs | 28 | 11th December 2002 06:18 AM |
| Page generated in 0.15166 seconds (65.55% PHP - 34.45% MySQL) with 10 queries |
