My brother has a Nakamichi 410, 420 & 430. I believe these things are from the '70s. Naturally they need a little work. Does anyone have any info, service manuals or schematics?
#2 |
They shouldn't be too hard to figure out. Work carefully and take pictures before you start!
-Chris |
#3 |
Yep, The initial problem is, the pre has a bad dual volume pot... And, the Tuner never realy tuned good...
Nothing major yet... But it did not sound as good as I expected on his little Alessi Monitors??? |
#4 |
Hi flg,
It may be the small monitors. The build quality on those Naks should be pretty good. Given the age of them, have a good look at the power supplies and coupling caps. Replace the preamp's ceramic caps with mica, and the audio path of the Tuner if there are any in there. Test on some bigger speakers that you are familiar with. -Chris |
#5 |
Well, I was thinking the power supply caps were a givin... Coupling, I'll do the best I/he can afford/fit and mica ha? The tuner, I was hoping to tweak??? Even my brother mentioned that? He's a Cheff??? Any real Idea's there???
I don't have any familiar speakers right now...Just moved and the crappy boxes for my F20BU's had to go... Yea I know... Thanks |
#6 |
Hi flg,
Tweaking tuner alignment is a pro's job with special equipment not found in your average shop. That's off limits. Coupling caps are not expensive. You want to use a good type, not a name brand. -Chris |
| Three 10" 4Ohm subs, wired in series or series-parallel? | Nagamitsu | Car Audio | 24 | 10th May 2009 03:24 AM |
| Yamaha CA-series / CT-series parts | DragonMaster | Parts | 9 | 19th January 2007 07:48 PM |
| Tweeter from B&W series 800 series 3 | pirat | Multi-Way | 3 | 1st May 2005 07:39 PM |
| Quality of Hammond 300 series power transformers compared to 200 series? | G | Tubes / Valves | 8 | 21st September 2003 02:27 PM |
| Fostex Z series, and EZ series? | bbaker6212 | Multi-Way | 0 | 13th June 2002 12:10 AM |
| Page generated in 0.42329 seconds (15.77% PHP - 84.23% MySQL) with 10 queries |
