Old 21st December 2006, 09:19 AM   #1
suzyj is offline suzyj  Australia-Aboriginal
suzyj's Avatar
Default My new baby amp
Hi guys,
Here's a gratuitous pic of my new amp - a little 50W lateral MOSFET design destined for my study. It's essentially the same topology as my 100W one (in turn based on David Tilbrook's AEM6000), but I've taken advantage of the lower supply rails (+/-40V rather than +/-56V) and used MMBT06/56s in place of many of the MJE340s and 350s. It also only uses one pair of 2SK1058/2SJ162 lateral MOSFETs.
It simulates very well - 0.0005% THD at 1KHz (50W into 8 Ohms), and 0.004% THD at 10KHz (50W into 8 Ohms).
Suzy
Old 21st December 2006, 09:27 AM   #2
can you post the schematic?
Old 21st December 2006, 10:21 AM   #3
suzyj's Avatar
Ask and ye shall receive: http://www.littlefishbicycles.com/poweramp/50W_amp.pdf
Suzy
Old 21st December 2006, 10:43 AM   #4
Very nice work. If I wasn't scared of SMD, I might give it a try.
Old 21st December 2006, 09:54 PM   #5
Awesome Suzy
Perfect layout as usual
I love those low profile caps...
Here is my latest little amp what do you think?
Old 22nd December 2006, 03:31 AM   #6
suzyj's Avatar
I'm squeezing a pair of these, a 120W toroidal transformer, a preamp board, and a control board into a box 170 x 185 x 100mm. The 25mm high caps (highest that will fit) were really hard to get.
Your board looks really well laid out. You really need some SMD parts though You could start with the odd melf resistor. It's a slippery slope from there.
Suzy
Old 22nd December 2006, 03:46 AM   #7
FastEddy's Avatar
" ... 0.0005% THD at 1KHz (50W into 8 Ohms), and 0.004% THD at 10KHz (50W into 8 Ohms) ..." ==== Aaaw 'some ...
Yes, what exactly is the total vertical height including any required stand offs or insulators?? (Will it fit inside a 1U rack mount chassis?)
A heat sink not required ?? (or is there some more parts we can't see yet?)
Kit soon? Modular amp soon?
" ... a preamp board, ..." ... ?? got a pic of that too?
Old 22nd December 2006, 04:03 AM   #8
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
a kit would be interesting!
fasteddy,
from what I can see the mosfets are under the holes between the power caps......then the board mounts on the heatsink much like the P68 or P101 amps from ESP.
Old 22nd December 2006, 08:43 AM   #9
felixx is offline felixx  Romania
felixx's Avatar
@suzyj
It seems you have a plate with an operational.
That don't "apear" on your schematics.
Could you tell us more about that?
"I'm glad I can build my own mistakes."
Old 22nd December 2006, 09:55 AM   #10
suzyj's Avatar
It's 33mm tall. 5mm for the MOSFETS (under the PCB), 3mm for the PCB, and 25mm for the filter caps. It'll fit easily into a 1U box.
The heatsink goes on the back. a pair of bolts go through the PCB, through the MOSFETs, and into the heatsink. It's a similar arrangement to what I did with my 100W amp.
Dunno about kits. It's too much of a derivative of Tilbrook's work for me to make money from.
The boards are designed but yet to be made for the preamp. It's a fairly simple affair with switching done using SSM2404 quad switches, an OPA2134 as a buffer, and a PGA2310 volume control.
Originally posted by felixx
@suzyj
I assume you're referring to the 8 pin SOIC? That's the SST404 matched dual JFET.
Suzy
My new baby GrahamnDodder Chip Amps 42 18th October 2003 03:49 AM
My baby is HOT!! jazzy Pass Labs 18 9th June 2003 10:37 AM
A Baby Zen V2 jh6you Pass Labs 13 1st October 2002 03:44 PM
Page generated in 0.10890 seconds (80.22% PHP - 19.78% MySQL) with 11 queries
