Hello
The power supply for my amp has quantity 4 of 15000uF caps in it. I'd like to try some power supply bypass capacitors. What type of capacitor and value of capaitor should I use? /.c |
#2 |
Bypass caps are generally Poly Film or polypropaline or Polyester or Polystyrene or Mylar, any Poly type Cap of the Largest Value you can fit (Usually between 0.1uF and 1uF) but larger the better and Poly Film or mylar caps are the smallest so they would probably be the best choise as you can get larger Values in smaller Packages....
Wima Caps are Popular and reasonably priced.... Cheers |
#3 |
"The power supply for my amp has quantity 4 of 15000uF caps in it. I'd like to try some power supply bypass capacitors."
A dual mono design with two 15,000µF per channel? Try between 22µF~47µF of a high quality electrolytic right on top of the big cans. Then try between 0.1µF~1µF as close to where the power is consumed. The grounds must return to where the star ground is. These may need a small value resistor in series with them, around 0R5. You may want to omit these caps if you can't get them orientated properly. |
| Type of .1uF cap to bypass Vcc & GND on chip? | riotubes | Parts | 2 | 20th October 2008 03:49 PM |
| What size capacitor I use for a 2A3 or 300B cathode bypass? | sgerus | Tubes / Valves | 20 | 4th March 2008 02:18 PM |
| bypass caps for bypassing mylar caps? | crippledchicken | Multi-Way | 4 | 27th February 2008 04:24 AM |
| Bypass caps on crossover caps... :D | quickshift | Multi-Way | 19 | 27th November 2005 12:59 PM |
| Speaker Class (type) vs Room Size | jomor | Multi-Way | 6 | 26th August 2005 11:44 PM |
| Page generated in 0.08799 seconds (63.27% PHP - 36.73% MySQL) with 10 queries |
