| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Hello,
I'll attatch two circuits. The first is a bit of a classic Graphic EQ design. Q1 : I want to know if the secong circuit would work, using multiple resistors (EQ by increments :-) instead of potentiometers, and if I could use only one array of resistors to do the job. In this example, I drew multiple SPST switches, but it could be jumpers for example. In the two drawings, I put two stages of EQ, but there could be any number. Q2: What are the best OpAmps (Quality + low power) for the job ? Q3: If the design works, would the resistor values better be calculated in pseudo logarithmic fashion ? Thanks ! |
#2 |
#3 |
LM4562, it is the best.
Gajanan Phadte |
#4 | |
Yes, multiple resistors would work. Some professional mixing consoles use such equalizers. A2: This is a tough one as the answer will depend on personal preferences and the budget available. A3: When potentiometers are used in professional audio, they are linear pots with center detent. When resistors are used (the way you are using them here), resistor values should preferrably model the S-curve. As an example, for attentuation values ranging from -10 to +10dB in 2dB steps, the following resistor string is used: 150, 180, 270, 270, 270, 270, 270, 270, 180, 150. Regards, Milan |
#5 |
| Thread Tools | |
| 5 Band Graphic Equalizer | NSLogan | Chip Amps | 2 | 17th June 2009 04:52 AM |
| Polystyrene caps in a graphic equalizer | stpa | Solid State | 3 | 10th April 2008 04:19 PM |
| DIY Graphic equalizer? | coldfuzion76 | Solid State | 4 | 18th March 2008 09:45 AM |
| Graphic equalizer | Buzzy | Parts | 1 | 24th July 2007 08:55 PM |
| Graphic Equalizer | Johnny25 | Parts | 5 | 29th March 2006 06:33 PM |
| Page generated in 0.15484905 seconds (78.40% PHP - 21.60% MySQL) with 10 queries |
