Old 19th December 2006, 09:15 PM   #1
Default Fixing old Sansui 5000a, fuse keeps blowing....
I replaced all the transistors to make sure they will be working. However if I even try to plug it in one of the fuses goes out (left channel). I have nothing plugged in, no speakers, no RCAs, nothing. The speaker position knob is turned to OFF and it still blows any fuse I put in.
Any ideas? I wish I had a schematic :/ There is an endless sea of wires and parts in it.
I realize this means a short somewhere but I am not sure were to start looking as this thing probably has a few miles worth of wiring in it.
Old 19th December 2006, 09:25 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Just a quick response, it's bedtime here.
Schematic: Have a look at Audiokarma.com , maybe they have it.
Fuse: If the power supply is a separate one for each channel, check the rectifiers and caps of that side.
/Hugo
Old 19th December 2006, 10:08 PM   #3
I will take a picture.
The fuses are interesting and appear to be connected to both amplifier boards.
Old 19th December 2006, 11:18 PM   #4
Old 19th December 2006, 11:21 PM   #5
There is a small board on the underside as well, not sure what it is doing.
Old 20th December 2006, 08:09 AM   #6
Well this is going to make a lame Christmas present... Here some decent speakers, a DAC with USB input and a reciever that does not work!
Old 20th December 2006, 11:17 AM   #7
Netlist's Avatar
This one shouldn't be too difficult.
First check for shorts between the metal case of the output transistors and the heat sink.
Check every semiconductor on the driver board, diodes included.
Check for burned resistors, replace the caps on that board.
Suspect the bias pot and replace if needed.
This is the best schematic I have so far.
/Hugo
Old 20th December 2006, 03:14 PM   #8
bikehorn's Avatar
how about checking for dead electro caps?
Old 20th December 2006, 08:02 PM   #9
I can not physically see any blow capacitors. I will check for ground shorts, that sounds like a likely problem. How do I know if a diode is bad? That also sounds like a likely problem. Whatever is wrong was most likely caused by over heating.
Thank you so much for helping me!
Old 20th December 2006, 08:08 PM   #10
Netlist's Avatar
First, report back on the possible shorts of the output transistors.
What did you replace them with?
Ohh...I just read your first post that says you replaced all transistors. How did you manage to get the originals? Or if you didn't, what are the replacements #’s?
/Hugo
Why does fuse keep blowing imhondamatt Car Audio 26 19th April 2009 07:14 AM
sansui 5000a schematic jblmar Solid State 2 2nd September 2008 05:55 PM
Sansui 5000A Transistors jblmar Parts 0 12th August 2008 08:38 PM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
Blowing my fuse (s) Jimlondon Chip Amps 7 7th March 2005 06:03 PM
Page generated in 0.10049 seconds (78.22% PHP - 21.78% MySQL) with 11 queries
