NAD 3020 amplifier volume problems
Old 19th December 2006, 09:15 PM   #1
Neilb is offline Neilb  United Kingdom
Default NAD 3020 amplifier volume problems
My 25 year old NAD 3020 has suddenly lost volume. It was working fine but suddenly went 'quiet'. If you go close to speakers, you can hear music very faintly. Any idea what problem is and if t can be easily fixed orhas it just come to en dof useful life? The same problem was raised by 'diddytong' in july 2005. Help!
Old 20th December 2006, 03:40 AM   #2
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Default NAD Volume Control
Hi Neil,
I love NAD products! I have an older 2200PE Amp and 1155 Preamp. Also have a 7225PE receiver. All work beautifully! Something really cool about an S/N Ratio of 114dB! I bought my 1155 second-hand from a pawn shop a few years ago and had problems with the volume control (noisy and music would cut out entirely sometimes). I replaced it with a new one, and Voila! Problem gone.
Since you're still hearing music faintly, your amplifiers are functioning. If the volume control is not suspect, then I would check any logic-controlled muting circuits to see if they're acting up.
Since I am unfamiliar with the 3020, I would ask: Does it use a true analogue potentiometer or a rotary encoder with digital volume control?
Sorry to present you with more question than answers, but these are a few things you might try out first.
Hope this helps out!
Kind Regards,
Steve
Old 20th December 2006, 03:51 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: NAD Volume Control
Originally posted by N-Channel Does it use a true analogue potentiometer
yes
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th December 2006, 03:35 PM   #4
very faint sounds like you are hearing crosstalk.
Is the input selector working correctly?
Switch off, swap leads to another input and check again.
regards Andrew T.
Old 20th December 2006, 08:33 PM   #5
All connections are correct - it was playing normally and volume just 'went'.
Old 20th December 2006, 08:49 PM   #6
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Schematic is here:
http://www.tcaas.btinternet.co.uk/index-4.htm
As a starter, you could measure at the pre-out/power-in connection.
/Hugo
Old 20th December 2006, 09:26 PM   #7
frugal-phile(tm)
planet10's Avatar
Here is the (early) 3020 service manual [11MB] ....
http://p10hifi.net/tlinespeakers/TLS...viceManual.pdf
and the 3020B schema
http://p10hifi.net/tlinespeakers/TLS..._schematic.gif
dave
Old 21st December 2006, 12:44 AM   #8
gmilitano is offline gmilitano  Canada
gmilitano's Avatar
This thread has my experience with a very similar problem and the NAD 1020:
http://www.diyaudio.com/forums/showt...threadid=62671
The 1020 is essentially the same preamp section of the 3020.
I had to remove the muting resistors. Play around with headphones and see if you have a signal in trhe preamp section. Or you can try put a signal into the amp section. That way you will know what section has the problem.
NAD 3020 amplifier volume problemsHide this!Advertise here!
nad 3020 problems reddish75 Solid State 0 19th May 2008 09:03 PM
problems with diy amplifier technics Solid State 4 23rd May 2003 07:30 PM
Annoying problems with Volume pot stigla Solid State 3 4th November 2002 12:08 PM
Amplifier problems... Diogo Solid State 1 31st August 2002 11:11 PM
NAD 3020 problems Neopsp Solid State 2 17th May 2002 03:34 AM
