Old 19th December 2006, 03:20 PM   #1
prorms is offline prorms  United States
Send a message via ICQ to prorms
Default how do you measure your in put singal to the poweramp????
ever time i measure the in put singal to the power amp i keep get 47 v now iam measure the singal with the multimeter setting i just would like to make sure my input singnal does not go over the limt
what would be the right setting or correct way to measure the input singal could please draw it out on the schematic just to make more easyer to understand?????????????????
its circle in red
Old 19th December 2006, 04:57 PM   #2
edl is offline edl  Hungary
edl's Avatar
The gain is determined by R9 and R6.
It's actually (22000+220)/220=101, equals 40dB.
It's way too large!
If your amp is rated 100W-RMS, than the input sensitivity is sqrt(100*8)/101=280mV. Its attenauted by R1, so it's 290mV.
Old 19th December 2006, 04:58 PM   #3
edl's Avatar
Hey, if you measure 47V-DC on the output, then...
Old 19th December 2006, 07:29 PM   #4
Default ...
say if wanted to hook up a singal generator if i measure in dc i get 0.1 mv
if measure in ac i get 1v
Old 19th December 2006, 07:32 PM   #5
edl's Avatar
Sorry, your english is too bad to understand.
Old 19th December 2006, 07:56 PM   #6
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
LMAO
Old 19th December 2006, 09:11 PM   #7
Default ....
is your input singal measured in ac volts or dc volts?????
going into the power amp??????????????????????????????????????????????? ?????????????????????????
Old 20th December 2006, 01:44 AM   #8
adason is offline adason  United States
adason's Avatar
Old 20th December 2006, 04:26 AM   #9
ReidK is offline ReidK  United States
Input is AC. DC should be 0 or close to it, though the input cap will block any DC.
Old 20th December 2006, 02:02 PM   #10
Hi Prorm,
I see you schematic has taken on board most of the earlier suggestions.
I still ask.
What is c6 doing?
Where is the resistor between the emitters of q9 & q11?
Disconnect or remove the output protection in the simulator (until you understand the operation of the amplifier and what the simulator predicts).
C3 forces the DCgain=1(one).
AC gain as Edl says. Reduce it to somewhere between 20 (+26db) and 50 (+34db) times.
The AC input signal should be 1mV to 100mV for non-clipping output.
Or, a little higher for examining the clipping behaviour (is a simulator any good at modelling clipping behaviour?).
What is your mother tongue? I and a few others are having a lot of difficulty translating your posts into plain English.
regards Andrew T.
iam getting radio singal when power amp is connected to waal socket ground prorms Solid State 1 22nd April 2008 07:53 PM
Poor preamp Singal To Noise Ratio steevo Solid State 47 30th June 2007 12:01 AM
how do you measure wattage of a poweramp???? prorms Solid State 10 12th September 2006 07:39 PM
Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? percy Multi-Way 0 12th March 2006 09:18 PM
Page generated in 0.13962 seconds (65.92% PHP - 34.08% MySQL) with 11 queries
