Hello All!
I was looking for a way to power a few cooling fans at 6 V or so, and ran across this project from Per-Anders: http://home.swipnet.se/~w-50719/hifi/mld01/index.html My questions are: 1. Can I use this with 120V mains to run cooling fans (of course component values should be changed to allow the correct voltage and current based on the equations provided on the page)? 2. Any drawbacks to doing it this way??? Opinions please!! Thanks in advance, Spence |
#2 | ||
hi
I would not do this. Even if I could. If only a few mA to power a LED lightning diode. Yes, maybe. But I wouldn't like to do it anyway ...... To drive any other circuit that takes more power, NO!!!! To drive even a very small FAN at 6 volt, you need more Current than a few milliampere. Use a little 6 or 9 Volt AC transformer. With a little 1-2 ampere rectifier bridge. You could regulate to get exact 6 Volt DC, by using 7806 3 pin regulator. (Or using LM7805 + 1-2 diodes to raise 5.0V get ~ 6 volt output.) I am sure peranders will agree to this is much better. ================================================ from peranders website Quote:
Small 3 pins voltage regulators, TO220 package, Max 1A = 1000mA http://www.fairchildsemi.com/ds/LM/LM7806.pdf See my attachment, for typical simple regulator circuits. Best to put LM7806 regulator at a piece of aluminium, at least for current above 0.1-0.2 Ampere and when is more than a few voltage drops from input to output. ( A transformer 9 VAC can have a rectified voltage ~13-15 Volt DC ) lineup |
#3 |
Thanks for the reply lineup! I will give the transformer/regulator option a try.
Best regards, Spence |
| PC Cooling Fans for Tube Amps | Dominguez | Tubes / Valves | 4 | 19th August 2007 01:06 AM |
| Page generated in 0.11848 seconds (59.60% PHP - 40.40% MySQL) with 11 queries |
