#41 | |||
![]() Quote:
Mister Pass have not often really cheated when he has published his amplifiers. Whether they are single end Class A or like here Complementary Class A or X or whatever he publish the recommendations of supply for his Amplifiers. It is not like we can see some of us others do. Just publish an interesting amp schematic with little or nothing else. Some even do not tell the level of V+ positive and V- negative. Which is one essential information. If you read the rather long and detailed article by Pass you will know how to build a very good amplifier: Amplifiers: Zen Variations - Part 5 by Nelson Pass (c) 2003 The Complementary Zen This is the final verdict from the constructor. The Conclusion. And I know Nelson is not a man often to say what he does not really mean or say too much. Quote:
Me, lineup say: I believe many of us could live with one Zen-v5 amplifier for very many years.
lineup |
#42 |
A good question. Here very few examples:
1) Moxtone Lab Simple 2 stage PP fet amplifier (post #1) 2) ABACUS (theoretical background, advantages in opposite to power followers, only in German) http://www.abacus-electronics.de/fil...no-prinzip.pdf and here additional URLs:http://www.abacus-electronics.de/files/spiegeltest.pdf http://www.abacus-electronics.de/files/info-ampino.pdf http://www.abacus-electronics.de/files/info-60-120b.pdf ABACUS electronics | ABACUS Abacus rieder 60-120 amplifier 3) "A new Class AB design" from the authors Wim de Jager, van Tuy & van der Ven (developed at University of Twente) Electronics World, December 1999, Page 982; only schematic: http://francis.audio2.pagesperso-ora.../C31_Jager.gif 4) LEF (Carlos Candeias, CEC/SANYO) detailled schematic wanted - who can post this ?? C.E.C AMP3300R (3300 R Amp 3300R Amp3300) and AMP5300R LEF Class A schematic wanted LEF (Load Effect Free) Amplifier technology 5) Linn power amplifier "Klout" (power stage) schema see attachement: Last edited by tiefbassuebertr; 4th May 2011 at 02:28 AM. |
#43 | |
For a current source, the power supplied to the speaker is P = R x Isquared For a voltage source, the power supplied to the speaker is P = Usquared/R Now the resistance of the speaker is never constant. When the resistance changes, the power supplied to it changes as well. In the case of the current source, the power changes propertionally to the resistance. In the case of the voltage source the power changes reziprocally to the resistance. Thus the voltage source incurs a lot more distortion than the current source. The current source is less susceptible to the phase shift incurred by the speaker as it is located in the voltage build up by the speakers resistance. This voltage, however, has little effect on the output stage. A voltage source, in contrast, has to supply the blind currents as well. To sum it up: a current source has much better control over the speaker than a voltage source. Another advantage of the current source is that one does not have to provide so much power. In the case of the voltage source the current increases when the speaker resistance drops, which is why those amplifiers need a lot of current (and thus: power) reserve. I think the 'warm' sound of the tube amplifiers has to be mostly credited to the fact that they are current sources, and less to the even harmonics distortion. Regards, gh |
#44 | |||
I suppose it might be possible to design a speaker to run from a current source, but most people design for a voltage source so the amp should approximate this. Most amps do this by sampling the output voltage for negative feedback. For a current source amp you would need a collector/drain output and sample the current, not the voltage. I have never seen this done for audio, although someone somewhere may have tried it. |
#45 |
The old Musical Fidelity A1 was a good example. Almost full Class A operation avoided any cross conduction problems. It had a 700mA quiescent and current limited at about 2A due to limited base drive, without any current limit circuit. The low voltage losses in the output allowed 20V rails and made the efficiency just about OK.
#46 | |||
Regards, gh |
#47 | |
Regards, gh |
#48 | ||||
#49 |
Here was a thread with follow topic, if I recall right
(the exactly phrasing was slightly different): Bob Cordell Interview: Emitter follower power stages vs. CFP (Sziklai) power stages Who can post the appropriate URL? |
#50 |
Emitter follower and CFP are both followers, even though the output comes from the collector in CFP.
| Open collector npn output | marjan | Solid State | 5 | 15th January 2005 07:40 PM |
| Common Source versus Common Drain output stages | alaskanaudio | Solid State | 33 | 27th March 2003 03:04 PM |
| cheap output stages | hacknet | Solid State | 0 | 8th December 2002 02:55 PM |
| Page generated in 0.16833 seconds (85.06% PHP - 14.94% MySQL) with 11 queries |
