Old 17th December 2006, 10:11 PM   #1
Audio Junkie
Zero Cool's Avatar
Default how to isolate input ground?
I need to build a simple opamp based preamp/buffer for an automotive project.
The Buffer is going to be used to interface an MP3 player to a car stereo. the problem is, a ground loop is created when the charger is plugged into the MP3 player as well.
Now the ugly cheap and easy solution is a radio shack ground loop isolator. yuck.
I need to come up with a better solution to do this.
The audio coming out of the MP3 player is unbalanced with a common ground. I have balanced inputs available going into the car stereo, or it can be used unbalanced. The radio shares ground with power, data and audio internally.
I dont have much room inside the case to hang iron and getting small, high quality iron is difficult and costly. so i am looking for some other solution.
Can i simply tie the opamp input neg side to ground through a 100 ohm resistor? Would that be enough to break the ground loop? I thought i had seen that done elsewhere. But wouldnt noise on the ground line then inject noise into the neg side of the opamp?
Help would be greatly appreciated.
Zc
how to isolate USB/audio ground?? audiomodder Parts 11 29th July 2009 09:26 PM
Car amp design, differential input, ground Davide82 Car Audio 11 12th November 2008 07:41 PM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
input connection and ground on ucd 180 bcrazy Class D 2 21st March 2007 04:23 PM
Page generated in 0.06031 seconds (65.86% PHP - 34.14% MySQL) with 10 queries
