Old 17th December 2006, 03:34 AM   #1
RyanW is offline RyanW  Canada
Default DIY Interconnects
Interested in making a high quality interconnect for cheap. Can a person use coaxial cable with RCA plugs? Seems that this would be cheaper than expensive Monster cable. There are a lot of reviews regarding silver and solid strand etc... but not much discussion about good quality, cheap DIY interconnects.
Old 17th December 2006, 04:07 AM   #2
vinylkid58's Avatar
Sure. I have some diy RG8 coax interconnects, RCA to XLR, which sound fine IMHO. I made some Cat5 Plenum grade RCA-RCA interconnects for my phono stage, which also sound fine. They have cheap gold plated plugs on them.
Just google "DIY Cat5 interconnects" and there should be lots of info/sites.
Jeff
Old 17th December 2006, 05:40 AM   #3
serengetiplains's Avatar
Get some Belden foamed teflon dielectric twisted pair wire, keep the twisted pair, chuck the rest, *including* the shielding .... second only to bare silver wire. Solder directly if you can. Avoid connectors.
Tom
Old 17th December 2006, 06:05 AM   #4
Default Re: DIY Interconnects
Coax may indeed be the best-sounding option -- period -- if you can live with the stiffness of solid-core. Some brands/models that stick out are:
Belden BL-1694A, Belden 1505F and Canare LV-77S.
Old 17th December 2006, 06:22 AM   #5
Great input!
What is your opinion on cheap Radioshack grade coax? Further, I am building a pair of GB300D's and SKPre's. Would this be an appropriate material to use within the pre-amp and amp cases for all of the low level signal wiring?
Old 17th December 2006, 06:34 AM   #6
Belden 89182, Belden 89182!
Tom
Old 17th December 2006, 07:28 AM   #7
don't try this on connectors from your tt to the phono preamp.
Old 17th December 2006, 07:52 AM   #8
Nordic is offline Nordic  South Africa
Nordic's Avatar
Yeah, old Rudi dosn't post here that often anymore, but he sent me my first sample of RG8.. certainly made an improvement to my amp at that stage. Just wish the stuff was not so unwieldy and rigid.
Old 17th December 2006, 10:59 AM   #9
aerial cable @ 6 to 9mm diameter is too stiff for internal wiring.
If your case is non conducting then shielded microphone cable should be OK @ 3 to 4mm diameter. Shielded down to 1.2mm is available, but difficult to source at the smaller end.
For a shielded type case you may get away with unshielded between stages or even twisted pairs (0.6mm solid core or 1pair from CAT5).
There may be more advantage in twisting the HIGH current conductors to reduce the fields emanating from them than protecting the low current conductors.
regards Andrew T.
Old 18th December 2006, 09:20 AM   #10
dfdye is offline dfdye  United States
dfdye's Avatar
I personally like guitar cable + RCA plugs. It is made to be flexible and it is pretty well shielded. It has benefits of shielded coax while being a lot easier to work with and bend around equipment. That being said, I also have a bunch of RG8 for BNC connectors, and it works great for audio too.
My concern with Radio Shack cable would be A) it wouldn't fit standard RCA plugs, and b) that stuff is really hit or miss. I would rather go to Lowes/Home Depot and get some of the high grade coax if you are going to use "TV Cable" coax.
Just my $0.02
Interconnects planarboy Everything Else 0 30th June 2008 01:01 PM
Best Interconnects? Eric_B_C Everything Else 7 2nd January 2007 04:39 AM
help please with interconnects! shepperd Parts 11 13th November 2006 06:09 PM
DIY Interconnects ralph-bway Everything Else 2 20th October 2003 11:02 PM
Cat 5 interconnects ddatta Everything Else 6 19th March 2001 02:42 PM
Page generated in 0.09880 seconds (79.57% PHP - 20.43% MySQL) with 11 queries
