Randy Slone "Fig 11.6" amp, modded: will work? - Page 9 - diyAudio
Old 8th January 2007, 01:27 PM   #81
your C3 is fairly close (looks about 20 to 30mm away).
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th January 2007, 01:44 PM   #82
tcpip is offline tcpip  India
Yes, I too was of the opinion that the current placement of the caps C3, etc are not too bad because (i) they're feeding input+VAS which are not very high current draws, and (ii) they are fairly close already. And if push comes to shove, I wanted the C3 to be close to the input stage rather than the VAS, because I thought that stage would be more sensitive.
Old 15th January 2007, 02:58 AM   #83
Do these L-MOSFETs need shoulder washers on their bolts to fix them to the heatsink? I know the 2SA1943/5200 BJTs don't need shoulder washers, because the metal surface on their rear sides don't touch the central hole, hence that surface never makes contact with the bolt.
If you guys don't use the term "shoulder washer", I'll explain. These are small insulating washers which are put on bolts when you bolt a TO3 package to a heatsink. This prevents the bolt from ever touching any part of the TO3 metal body.
Old 15th January 2007, 12:02 PM   #84
I think all the To264 & To247 have the same isolated hole for the bolted fixing.
Many advise adding a flat washer to spread the bolt head load over the face of the semiconductor package.
regards Andrew T.
Old 17th January 2007, 02:09 AM   #85
Great. This makes things easier.
Yes, I always do this. But since there's no electrical issue here, I can use a metal washer.
Old 29th May 2007, 11:31 PM   #86
Flavio88's Avatar
hi tcpip, i need the eagle file of the slone 11.6 amp schematic.
Can you mail me that file?
Thanks...
Randy Slone's "Fig 11.4" (Self's "Blameless"?): PCB layout tcpip Solid State 128 23rd September 2013 05:45 PM
Randy Slone 6.6 design py Solid State 8 20th July 2011 03:06 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 04:47 AM
Randy Slone JDDCo Solid State 6 22nd September 2006 03:57 AM
OPTIMOS-Amp from Randy Slone wopo Solid State 1 12th July 2004 09:18 PM
Copyright 1999-2017 diyAudio
