Old 14th December 2006, 08:29 PM   #1
prorms is offline prorms  United States
Send a message via ICQ to prorms
Default math problem ??
1/(2*pi*22k*47nF)
PLEASE SHOW ME THE MATH
Old 14th December 2006, 08:36 PM   #2
The one and only
Nelson Pass's Avatar
Frequency = 1/(2pi R C)
2pi = 6.283
R = 22k = 2.2 x 10 ^ 4
C = 47 nF = 4.7 x 10 ^ -8
2pi RC = 65 x 10 ^ -4
1/(2pi RC) = 154 Hz
Old 14th December 2006, 08:44 PM   #3
Nordic is offline Nordic  South Africa
Nordic's Avatar
While I have you here... how do I convert times into gain if you get what I mean....in db
Old 14th December 2006, 08:54 PM   #4
db=20*(log (gain))
If gain is less than 1 then db comes out as negative.
gain = 2times >= +6db
gain = 20times >=+26db
gain = 0.5times >=-6db
when comparing power. db=10*(log(power ratio))
regards Andrew T.
Old 14th December 2006, 09:33 PM   #5
let make sure i understand you
2*pi*r*c
2*3.14=6.28
6.28*22000=138160
138160*0.000000047=0.00649352
m=1000000
k=100000
hz=100
mF=0.000
uF=0.000000
nF=0.000000000
pF=0.000000000000
HERE MY UNDERSTANDING HOW TO CONVERT
RESISTORS AND CAPACITORS
BUT DONT UNDERSTAND HOW TO CONERT IN TO Hz
Old 14th December 2006, 10:06 PM   #6
The one and only
2 X PI X FREQ = 1/RC
R IN OHMS
C IN FARADS
That's all there is
Old 14th December 2006, 10:12 PM   #7
AKN is online now AKN  Sweden
Enjoy good sound
AKN's Avatar
1M=1000000
1k=1000
1m=0.001
1u=0.000001
1n=0.000000001
1p=0.000000000001
1/0.00649352=154Hz
All at once: 1/(2*pi*22000*0.000000047)=154Hz
/ Anders
Old 14th December 2006, 10:56 PM   #8
Enjoy good sound
AKN's Avatar
Hi prorms,
Little more
0.00649352 this is actually the period time at the corner frequency you are calculating. Period time is the time from one zero crossing to another, eg 360 degree or 2pi in radians.
Frequency=1/t
/ Anders
Old 19th December 2006, 08:48 PM   #9
Hi Prorms
If you turn your equation round, swapping f and R, the impedance of a capacitor is
(R=) Z=1/(2*pi*f*c)
Note the use of Z instead of R because it is reactive even though Z and R are both measured in ohms.
Time can be used instead of frequency, because the time period t=1/f so that we can also write
Z=t/(2*pi*c)
and we can swap C and Z (R) again to give
C=t/(2*pi*Z)
Why bother with all this swapping? Here's the point: the units of capacitance can be stated to be seconds (from the t) /ohm (from the Z) and this means that your answer in the original version f=1/(2*pi*R*c) is already in Hertz because the time-dependency is included in the C.
Cheers
John
Son of Zen and math bertjan Pass Labs 5 10th February 2006 02:51 AM
Can't do the math! poorstudent Full Range 3 22nd November 2005 06:37 AM
Need some Math Help... ctardi The Lounge 3 21st June 2005 05:11 PM
Page generated in 0.11334 seconds (65.39% PHP - 34.61% MySQL) with 10 queries
