Just finished replacing all shorted O/P trans on this amp.
With a lamp in series with ac line all is ok both amps run perfectly. But if you plug amp directly into ac supply with bass spkr connected O/P stages Blow. All - + supplies ok in tolerence no ac ripple. On the the 300w side there is a large voltage swing at turn on at the Spkr terminals to the -VE rail Also with no spkrs connected and amp turned on the off 300W amp o/p terminal goes to -ve rail. This does not occur on on the 100W section . If you run the amp with the ac supply in series with a lamp and the bass spkr is connected before you turn the amp draws massive current. However if you connect the spkr after you turn on all is ok. Inject 1k sine at input stage no distrtion waveform is symetrical on o/p all voltages at each stage are correct!!! SO what is causing this large neg voltage swing at turn on and turn off?? Interestingly in the S/manual GK mentions bringing up the amp on a variac at approx 50v the amp O/P will swing negitive and snap back to 0v which it does. |
#2 |
Audio Junkie
HMMM maybe look at the input section. neg feedback side...maybe
#3 |
Check the driver stages too.
| need help with gallien krueger 800rb | dkdeleon | Solid State | 19 | 3rd June 2010 09:27 PM |
| Blown up GK 800rb | mpm32 | Instruments and Amps | 1 | 13th April 2007 09:20 PM |
| Galien Krueger 800RB blows main fuses | david maurer | Solid State | 2 | 25th May 2006 07:57 AM |
| gallien krueger 800rb no sound | dkdeleon | Instruments and Amps | 1 | 30th October 2005 06:49 PM |
| Page generated in 0.09272 seconds (56.95% PHP - 43.05% MySQL) with 10 queries |
