AD797 Clone people! Who can make a better one.
Old 12th December 2006, 12:00 PM   #1
lineup is offline lineup  Sweden
lineup's Avatar
Lightbulb AD797 Clone people! Who can make a better one.
hi
Everything tells me, that AD797 is not only a very good operational amplifier
The topology used has got to be something extremely good!
Using only the simplified schematic from Analog Devices datasheet
I get some extraordinary simulation results.
(And I am used to see a few good figures, from my own circuits. Using same transistors.)
A few details from me, for those who want to try to make a better AD797 Clone.
... but I am not sure anyone could do this better than myself
... maybe get some similar results, but not better, I doubt.
My circuit is in attachment and follows the AD797 schematic
- what I know from reading This Datasheet Very Closely
Lineup Audio Lab
AD797 Clone - version 2a
by lineup
... Supply +/- 15 Volt DC
... Test 10 Volt RMS into 2.2 kohm, = 14.14 Volt peak!!!
... Gain= x10, +20dB
... Frequency, -3dB at 600kHz
... THD <0.001%, my MultiSim does not show anything = 0.000%, see picture
Some more details:
All transistors BC550C and BC560C.
Total Supply Current 8.0 mA
Output stage, like the original biased only 0.5 mA ( 492uA more precise .... )
Good Luck Fellowes!
You may need really it
lineup
Old 12th December 2006, 12:09 PM   #2
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, Lineup,
How about LM4562 ? Do you know what is the simplified schematic of this opamp?
Old 12th December 2006, 12:38 PM   #3
PMA is offline PMA  Europe
PMA's Avatar
Why did you cover the folded cascodes and current sources, connected to input differential pair?
Old 12th December 2006, 12:58 PM   #4
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default Re: AD797 Clone people! Who can make a better one.
Originally posted by lineup
hi
Good Luck Fellowes!
lineup
In the sim you have perfectly matched current sources, perfectly matched transistors, of course your THD is close to zero.
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 12th December 2006, 04:08 PM   #5
Christer is offline Christer  Sweden
Linup,
did you use the compensation cap(s) to reduce distorsion, as suggested in the datasheet?
Old 21st December 2006, 09:39 AM   #6
lineup's Avatar
Thumbs up Re: AD797 Clone people!
The above was an AD797 Analog Devices operational amplifier CLONE.
Where I tried to make as perfect discrete copy as possible
of this high very performance and expensive AD797
I now have used same basic topology, with some changes
to try to get some other 'improved features and data'.
The circuit still has got a diamond output buffer,
but here I have used Low Noise High Voltage JFET 2SK373, 100V, for input pair.
Instead of low-noise bipolar BC550C, 45V
And 150V transistors 2N5551 - 2N5401 for rest of this amplifier.
This gives my New Op-Amp Max supply of 100 VDC, or Dual supply +/-50 Volt.
Test results at unity gain and +/- 40 VDC
were performed at 1kHz
- 20 VRMS input = output. Peak: 28.9 volt input ... 28.3 volt out
- Into 2 kOhm resistor LOAD
THD shows 0.000%
See link below for Fourier analys of Separate Harmonics.
My simulation test setup of this discrete Op-Amp here:
http://www.diyaudio.com/forums/attac...amp=1166531312 (image)
Read more details of this Lineup Audio Project
and about 2SK373 JFET for 100 Volt
in this post:
Extreme Performance Discrete Op Amp - 2SK373 2N5551 2N5401
lineup discrete op amp man
lineup
Old 21st December 2006, 11:32 AM   #7
thanh is offline thanh  Viet Nam
thanh's Avatar
Send a message via Yahoo to thanh
Your job is very intersted in. Can I view the schematic with all detail ?
thanks!
Justice for Victims of Agent Orange
http://www.petitiononline.com/AOVN/Thank all of you!
Old 21st December 2006, 12:34 PM   #8
GRollins is offline GRollins  United States
As janneman hinted earlier, anyone can build a 'perfect' circuit in a simulator. There is a great deal of difference between the fantasy of perfect components and the reality of imperfect parts out in the real world. Even matched transistors do not approach the ideal units in a simulator.
Grey
Old 21st December 2006, 12:45 PM   #9
edl is offline edl  Hungary
edl's Avatar
Halojoy (Lineup),
This topic is a joke (too).
GRollins,
I agree!
Old 21st December 2006, 01:03 PM   #10
ashok is offline ashok
ashok's Avatar
Lineup......What software are you using for analysis ?
Thanks.
Ashok.
AM
AD797 Clone people! Who can make a better one.Hide this!Advertise here!
AD797 discrete clone - comparison of seven variations tiefbassuebertr Solid State 14 9th January 2010 11:52 AM
AD797, how to make the best of it nelsonvandal Solid State 56 22nd October 2008 01:08 PM
