Old 11th December 2006, 12:35 PM   #1
Send a message via MSN to christianlie
Default The best DIY monoblock?
I would like to know what DIY monoblocks are the best out here, the one you would like the most to have yourself. And it would be nice if it available finished only without the case. I want to do a project like this mostly because of doing my own visual design, and I dpont know much about the tech spec behind an amp.
Old 11th December 2006, 01:30 PM   #2
AMV8 is offline AMV8  United Kingdom
Hi
The most popular diy monoblocks are the Krell ksa50 and the Pass labs designs. There is a thread on the Krell Ksa 50 and a home page at Pass diy and Passlabs for the pass amplifiers. I have built both and found them excellant offering high quality audio.
More ambitious amplifiers, which require more knowledge, are the Krell KSA 100 and the Pass labs X amplifiers. There is a thread for the Krell KSA 100 and the pass amps are on the home pages mentioned above.
Other amplifiers, which I understand are excellant but which have less threads to support you, are those from Borbelly and Leach and also Rod Elliot.
Another interesting design with less power is that from Lindsay Hood. Again check the threads here under that name.
Good luck and I hope you post some pictures when you have finished to give everyone some ideas for the future.
Don
Old 11th December 2006, 02:58 PM   #3
tinitus is offline tinitus  Europe
As you state that you want something premade theese guys will be on top of my list
Gregs design appear to be popular
http://www.diyhifi.org/amplifierguru/guru_001.htm
Anthony is "old" in this game and his revised design seems interesting - I might be interested in the coming NX400
http://www.aussieamplifiers.com/index3.htm
If you want class-D theres Coldamp, UCD and the small cheap ones from "41hz"
Old 11th December 2006, 04:19 PM   #4
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Christian,
if you have little technical knowledge/experience in amplifier building, i suggest the easiest to build monaural design instead of the best.
Don Lagonda,
you skipped on an attempt to climb the A100s, i gather from your words ?
(referenced by D Self-kicker in his book, btw. Lindsay=>Linsley, unless he had a drag Q brother)
Looks like Sponge Bob has killed another thread.
Old 11th December 2006, 04:29 PM   #5
I want it pre built and then I can fit it in a cabinet, fit power switch, rca,xlr and speaker terminal, and connect the other main parts. But there is no way I am skipping out the best sound to make it easier to build, then I will probably buy Krell, Pass Labs, Theta or Mark Levinson monos instead. I need the top sound quality. Is the GB300D a way to go?
Old 11th December 2006, 08:57 PM   #6
AKSA is offline AKSA  Australia
Christian,
It rather depends on how much service backup you need, and the level of completeness of the kit. Like anything, there is a complete range of prices, too, but if you look carefully at all the suggested options you will see the whole range of service, price, and completeness.
I offer a complete kit, with full service backup, but your decision is a tough one.
All the amps suggested are good, with anything by Linsley Hood or Nelson Pass a standout.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 11th December 2006, 09:01 PM   #7
Hi Christian,
is your speaker the Prodigy?
What impedance is it?
How loud do you listen?
The answers may rule out many good sounding options!
regards Andrew T.
Old 12th December 2006, 12:22 PM   #8
The speakers I am running at the moment is the Odysseylogans, the run really low on impedance sometimes and are power thirsty, I do not listen very loud, but imo a larger more powerful amp has the better control of the speaker.
Old 12th December 2006, 01:45 PM   #9
Originally posted by christianlie
Odysseylogans.......really low on impedance sometimes ........are power thirsty
details please.
regards Andrew T.
Old 12th December 2006, 02:19 PM   #10
I would say that you will benefit from running a kit at lower voltage than its rated value, to get better current stability in low impedance - maybe about one third of its max possible output - and still use lots of cooling, as if it was a class-A
845 A2 Monoblock Project Bryan Tubes / Valves 299 10th December 2010 04:46 PM
Yet another monoblock Sch3mat1c Solid State 4 22nd August 2009 01:00 AM
Monoblock Vs Stereo samsagaz Everything Else 12 27th April 2009 10:21 AM
a 71A monoblock Joel Tubes / Valves 30 30th December 2002 10:19 PM
Page generated in 0.11280 seconds (84.58% PHP - 15.42% MySQL) with 10 queries
