Old 11th December 2006, 03:39 AM   #1
Send a message via MSN to jamesfromkansas
Default crown ma10000
How much did the Crown MA10000 cost when it came out? I have one but I don't know what it is worth in mint condition. Thanks in advance.
Old 11th December 2006, 03:47 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: crown ma10000
Have you searched to web.
eBay and other such second hand places
may have some Crown MA 10000 on sale.
And may see some prices, money wanted and offered.
There are many other 'Buy & Sell' websites, too.
eBay has got good search functions for anything
one search category is 'Consumer Electronics'
http://www.ebay.com/
At http://www.crownaudio.com/ I digged up this Crown Macro-Tech 10000 PDF
including some schematics, but maybe not the power output part:
http://www.crownaudio.com/pdf/legacy/k80305a2.pdf
More Documents:
Discontinued Product, Product Documentation
http://www.crownaudio.com/gen_htm/legacy/legacamp.htm
What I can understand it is a very high power amplifier (needing special Mains Powering)
According to the above PDF, looks like:
Continuous Average Power output, 1 kHz:
At 0.1% THD !!!
4 Ohm: 2.190 Watt
2 Ohm: 3.895 Watt
1 Ohm: 5.880 Watt
I guess, you would easily find a buyer,
that would be willing to pay Very Good Money
maybe even in the Trading forum category of www.diyaudio.com
Link:
diyAudio Forums > Top > Market Place > Trading Post
http://www.diyaudio.com/forums/forum...p?s=&forumid=2
lineup
lineup
Old 11th December 2006, 03:51 AM   #3
FastEddy's Avatar
New in 1988. US$4000 or a dollar a watt, installed with a warranty, is a good guess.
Old 11th December 2006, 08:28 AM   #4
djk is offline djk
djk's Avatar
"you would easily find a buyer, "
As long as they have three-phase power available.
Old 11th December 2006, 08:51 AM   #5
lineup's Avatar
Default Re: Re: crown ma10000
At 0.1% THD !!!
4 Ohm: 2.190 Watt
2 Ohm: 3.895 Watt
1 Ohm: 5.880 Watt
Yes, that's right.
as I told: (needing special Mains Powering)
But wouldn't almost anyone with his own house, have access to 3 phase mains?
And as of today:
www.diyaudio.com: 64,713 members
Can be quite a big number of potential buyers, that has got what it takes.
Even if only a small % has got 1 house.
Say 5%. Makes 3.235,65 diyaudio members have a house.
(Well a bit difficult if you are that one 0,65 of a person, maybe.)
And this guy only needs ONE ( 1 ) Very Interested person
to be able to sell his amp.
No problems at all, what I can see. Power and Very High Power sells ... !!!
lineup
Old 11th December 2006, 11:45 AM   #6
djk is offline djk
djk's Avatar
In the USA residences are wired for single-phase.
Industrial areas are three-phase 'Y', commercial areas are often three-phase open Delta.
The open Delta will run air conditioners (in food places, shops, and such) and air compressors (in service stations and such), but will damage an amplifier connected to the 'wild leg' (open Delta).
A Crown VZ5000 will do 5KW at 1 ohm, 4KW at 2 ohm, 2.6KW at 4 ohm, and runs off single-phase.
Open Delta is not used for new construction, but is grandfathered in (not required to be up-dated) for older cities.
Most clubs I had to set up sound in were either single-phase, or open Delta, only one was 'Y' (in a three state area).
In the city I live in the old coal fired utility still generates DC for one industrial customer, and to generate steam for the downtown area. The nuclear plant runs everything else.
Old 11th December 2006, 02:04 PM   #7
Audio Junkie
Zero Cool's Avatar
The crown Ma10K will run at a quarter ohm! Many of these were modified as gradient amps for MRI machines to run the big coils. I have no idea what a gradient amp is or how it is modified but many have been for sale on ebay. I was told that when modified there Freq resp would only go up to 5K. I have no idea if that is true or not.
Trivia, On one tour, Micheal Jackson used 16 Servo Drive subs running of a MA 10K. the sound guy had a DBX subharmonic processor running through a Dunlop volume pedal and out to the amps. when they wanted some low end, the sound guy just stepped on the pedal and cranked those bad boys up!
Old 11th December 2006, 03:01 PM   #8
My jobmate have 4 of them (MRI machines version) in his house! they are not used from now because of the circuitry of preamp is different.. no jack or rca or xlr... only data connector style.. maybe some DAC inside.. but we plan to modify one of those to operate at on 230VAC.. we removed the transfo from one (BIG tri-phase transfo!) and plan to use many single phase transfo in parallel instead of this one.
They are heavy!! more than 100pounds each and they have
82 transistor to-3 inside for the output . some big cooper busbar inside too.
Maybe he is interested to sale some. just contact me about that.
They are in good shape and was used in medical department of university of Sherbrooke.
Old 23rd December 2006, 12:24 PM   #9
Audio Junkie
Zero Cool's Avatar
Doctorbass,
I would love to see the insides of one of these amps. any chance you could post some photo's?
Zc
Old 23rd December 2006, 01:32 PM   #10
Especially this afternoon i will take some cause i will see him.
You want some.. I'll give you some!!
I will post that in the next days
I really think that this post will become very popular after doing that!.. maybe i will post a vid of the inside and put that on youtube!!! what do you think??!!
Mery christmas!
Doc
crown xls 602 amp galush Solid State 0 6th April 2009 04:41 PM
FS: Crown CH2 imix500 Swap Meet 4 5th November 2008 11:52 AM
Crown Com-Tech 210 Power Amplifier Crown Com-Tech 210 tyler477 Solid State 1 31st October 2008 04:24 AM
crown k2 themedium Solid State 1 19th November 2006 08:25 PM
QSC/Crown and the like Madmike2 Solid State 4 3rd May 2005 10:38 AM
Page generated in 0.12721 seconds (72.54% PHP - 27.46% MySQL) with 10 queries
