Old 30th December 2006, 02:24 PM   #11
d3imlay is offline d3imlay  United States
I was doing contract tech work for SoundValves when they sold these amps. I tested them before they shipped out. Output was only 54 volts as I recall. However they would go down to .5 ohms or so. Do the math. The versions I saw were the gradient drives. I understand they drove the X/Y fields in an MRI.
I used one as a variable frequency source driving a stepup xfmr. I could get 5KW at 45-65hz/240 volts. I did blast the amp a couple times, I think due either to kickback from the xfmr or the low power factor. I pulled the defective transistor out and kept on going. In their original application they had something like a .05 ohm 250 watt resistor in series with the output. The tech manual showed how to series/parallel these amps for more voltage/current.
The design was an H bridge. 4 "wells" as Crown called the heatsinks. Seems like each well had 20 TO3's. You can run these single phase 208/240 but you have to mod the power supply board. Of course output power would be reduced to less than 50%.
Old 27th May 2010, 10:05 PM   #12
SOSamp is offline SOSamp  United States
Default Crown MA-10000
I have a Crown sales pamphlet that states weighs 128 lbs and is designed for loads under 1 ohm. No wattage specified. I believe it put out 1KW at 8 ohms. No list price specified, but I think it was $10,000.00. There is no date on the pamphlet.
crown xls 602 amp galush Solid State 0 6th April 2009 04:41 PM
FS: Crown CH2 imix500 Swap Meet 4 5th November 2008 11:52 AM
Crown Com-Tech 210 Power Amplifier Crown Com-Tech 210 tyler477 Solid State 1 31st October 2008 04:24 AM
crown k2 themedium Solid State 1 19th November 2006 08:25 PM
QSC/Crown and the like Madmike2 Solid State 4 3rd May 2005 10:38 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
