Old 10th December 2006, 10:37 PM   #1
Send a message via MSN to christianlie
Default Diy noob want to build monoblocks.
I have for a long time wanted to build my own monoblocks, and I think I now is the time to start as I have some time to spare. The problem is that I know absolutely nothing at all about this. I Need the amps to run a pair of Martin Logan Prodigy speakers. What I need is an advice for an amp that can do the job and deliver the best sound for the bucks. I need a complete set, or a list of what I need of parts to pull this of. I hope some of you uys can help me out and help me make a proper high end component. Thanks.
Old 11th December 2006, 01:51 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Seems that you need something high power to drive your Martin Logan.
Old 11th December 2006, 02:57 AM   #3
LineSource's Avatar
Take a look at the Krell KSA100 rev2 thread. This ClassA topology will drive over 200 watts into 4 ohms, and with the proper power supply, also drive the 1 ohm impedance minimum spec'ed by Martin Logan. The initial DIY listening impressions are positive, as were the original reviews for production KSA/KMA 100.
Description: Hybrid electrostatic/sealed-box moving-coil loudspeaker. Drive-units: 48" by 16" curvilinear electrostatic HF/midrange panel; 10" long-excursion, aluminum-cone woofer; 10" high-rigidity, high-excursion fiber-cone woofer with cast basket. Bass-control switch: +3dB at 50Hz. Crossover frequency: 250Hz. Crossover type: quasi-second-order, 12dB/octave. Frequency response: 28Hz-22kHz, ±3dB. Dispersion: horizontal, 30 degrees; vertical, 4' line source. Sensitivity: 91dB/2.83V/m. Nominal impedance: 4 ohms. Minimal impedance: 1 ohm at 20kHz. Recommended amplification: 80-300W.
Old 11th December 2006, 08:57 PM   #4
I have only heard a Krell once and I have no idea what model it was.
After following the KSA50 thread for the past year and now the KSA100, I can recommend the Krell Klone for extreme duty amplification.
Once you decide, join us and give us some details of your requirements.
The experts there will guide you through procurement and building.
regards Andrew T.
Noob's first build !!!! bereanbill Tubes / Valves 13 20th April 2009 10:15 PM
Speaks build.... a few P.Daniel LM3875 monoblocks.... speakrsrfun Chip Amps 5 13th March 2009 02:44 AM
what monoblocks to build? space-cake Tubes / Valves 4 5th June 2007 07:05 PM
Help a noob build a ZV9 neil_kaye Pass Labs 63 15th March 2007 02:18 PM
Page generated in 0.08312 seconds (72.75% PHP - 27.25% MySQL) with 10 queries
