Old 10th December 2006, 08:30 PM   #1
broka is offline broka  Chile
Default How I Can Bridge This Power Amplifier???
anybody has know how i can bridge the mosfet power amplifer AV-800????, i have the schematic diagram
Old 10th December 2006, 10:22 PM   #2
Hi Broka
Details On how to bridge the AV800 are in the latest Assembly Manual.
Plus many other enhancements made in the last few years.
It's very easy You will notice that the Av800 has Balanced Inputs
All you have to do is use the Inverting input of AMP A and Non-Inverting input of AMP B and the load is driven across the Active Outputs of each each channel and you have a Bridged AV800.
Your should get around 1800 watts with a 2KVA supply into 8 Ohms. From memory when I did that test I only used 80 volts supply.
Old 10th December 2006, 10:43 PM   #3
Default BRIDGING AV-800
for this shematics
Amplifier Av-800
your you could be but I specify??
put on your that i have 2 power av800...(with respect to the schematic ones previous), you can make a schematic???for i can to understand your idea...thanks
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 07:38 PM
Bridge amplifier on 8 om matic Solid State 8 16th September 2006 09:44 PM
Bridge SE amplifier croccodillo Tubes / Valves 3 17th February 2006 01:58 AM
TDA amplifier , Bridge , 600 W . darkm4n Chip Amps 0 29th March 2004 12:48 PM
how to bridge an amplifier MV Car Audio 1 25th March 2004 05:11 PM
Copyright ©1999-2013 diyAudio
