Class (A)B output stage: why 2 emitter resistors, why not 1?
Old 12th December 2006, 06:27 PM   #11
Wavebourn is online now Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally posted by deleveld
Yes I agree that symmetrical clipping is a good idea!
Do you mean 0.06% of power loss in one rail must be compensated by equal 0.06% of power loss on another rail for some good idea?
What is the reason behind this idea?
The Devil is not so terrible as his math model is!
Old 12th December 2006, 08:47 PM   #12
K-amps is offline K-amps  United States
K-amps's Avatar
To be a narrow mind.
Old 12th December 2006, 09:01 PM   #13
Nordic is offline Nordic  South Africa
Nordic's Avatar
Isn't odd harmonics one of the downsides to perfect symetry?
No wonder so many things in nature including ourselfes are not perfectly symetrical.
Old 12th December 2006, 09:09 PM   #14
deleveld is offline deleveld
Wavebourn, you make an interesting point.
I think one should try to maximise output swing before clipping occurs. I agree thats not a very objective statement. If fact it sounds like an ethical statement and I am not sure why it seems natural to describe it in those terms.
From an objective viewpoint you could consider that symmetrical clipping increases the probability that a random signal wont be clipped. Because you never know whether the signal peak will be +ve or -ve. An amp can only relaibly process signals smaller than its lowest clipping level.
I think that with a single emitter resistor then the clipping difference could very well be on the order of a few volts. If the difference in clipping levels is on the order of fractions of a volt, then the point of diminished returns has been reached. But when the clipping difference can be a few volts I think that some attention should, if possible, be paid to fixing the problem.
Doug
Old 12th December 2006, 09:10 PM   #15
K-amps's Avatar
Isn't it odd, that harmonics are one of the downsides to perfect symmetry?
OR
Aren't odd harmonics on of the downsides to perfect symmetry?
Which statement is the one you wanted to make...
As far as we go, I agree, assymmetry is built into our genome.... is that why we prefer some forms of distortion?
Old 12th December 2006, 09:12 PM   #16
K-amps's Avatar
Doug,
Would it be better opimized if you used a single emitter in a quasi-complementry OP stage?
Old 12th December 2006, 10:01 PM   #17
Wavebourn's Avatar
Doug
In the order of a few volts? One tenth ohm against 4 ohm load?
Let's check... Suppose, output voltage is 10V, it means 2.5A current, and 0.25V drop on 0.1 Ohm resistor, it means 0.625 W of power.
Now, you add 0.25V more of voltage drop claiming that output power before clipping will be higher? No, it will be less. Unaudible less, but anyway less.
So, what is the reason?
Old 13th December 2006, 03:25 AM   #18
CBS240 is offline CBS240  United States
CBS240's Avatar
No emitter resistors in a BJT EF could make biasing a bit touchy. Hope you have a good stock of outputs.
All the trouble I've ever been in started out as fun......
Old 13th December 2006, 04:10 AM   #19
GK is offline GK  Australia
Did you only use emitter for top or for the bottom output transistor?
I assume you had no particular problems with only one emitter resistor?
thanks,
Doug Eleveld
I put it in the top, but either way would have done. The resistor was 1 ohm, the output transistors were TIP31/TIP32 (that's what I had in my junk box). Driver transistor connections weren't an issue because there weren't any and the output devices were biased and temperature compensated with two 1N4001 diodes connected in series.
Pout was a massive 1.5 watts rms into 8 ohms.
Probably not what you were expecting!
Old 13th December 2006, 04:56 AM   #20
Wavebourn's Avatar
Why?
The same idle current flows through both transistors and their common resistor. The same biasing voltage is applied between their bases.
Where's the difference?
Class (A)B output stage: why 2 emitter resistors, why not 1?Hide this!Advertise here!
four transistor emitter follower (diamond buffer) as power output stage? capslock Solid State 114 22nd February 2015 10:51 AM
Do we always need an emitter follower to drive a LATFET output stage??? Leolabs Solid State 37 9th January 2011 04:16 PM
CFP output emitter resistors ian_elvar Solid State 17 3rd March 2008 06:40 PM
Emitter resistors in multiple BJT output stage bocka Solid State 37 8th October 2004 11:58 AM
Copyright ©1999-2017 diyAudio
