Parasound P/HP - 850 Preamp modifications
Old 10th December 2006, 03:36 PM   #1
firekat is offline firekat  United States
Default Parasound P/HP - 850 Preamp modifications
I have a Parasound P/HP - 850 preamp that I have been using only as an input for my audio restoration projects (records, tapes, radio) that I perform on my computer.
I would like to use the Parasound in my current equipment stack. I would like to be able to use it as a source select to feed my integrated tube amp, so I would not need the preamp section for that so I would like to bypass the amplification section. I intend make it switchable so that I could continue to use the Parasound amplification system for my audio restorations and also to feed a planned Class T amp.
I could not find any documentation on it. Looking at the unit it looks like it could quite easily be completed by lifting the incoming signal lines to the 50K volume control pot and inserting the appropriate switching & a few additional jacks.
Since I am no expert in all this kind of stuff would this create any problems?
Is there any other easy to accomplish hacks that would improve upon a very good design?
Additionally since I cannot locate my owner's manual does anyone know what the difference is between the "Normal" & "Direct" outputs?
Thanks All!
Parasound P/HP - 850 Preamp modificationsHide this!Advertise here!
Mixer preamp modifications joaoveludo Solid State 0 11th April 2009 10:21 PM
Parasound 2500 AV Controller preamp doerfast Swap Meet 0 23rd March 2009 05:48 AM
Counterpoint Preamp Modifications kensetsu Tubes / Valves 1 14th May 2005 12:29 AM
Parasound Preamp Troubleshooting mura Solid State 3 26th January 2005 11:31 PM
parasound p/ld 1100 preamp crippledchicken Solid State 0 16th January 2004 11:32 PM
Copyright ©1999-2017 diyAudio
