you can get one pair of 302/281 to run from +-39Vdc supply rails into an 8ohm load, giving about 55W to 60W into 8r.
For a 4ohm load the supply rails should be kept down to +-33Vdc and can give about 60W to 65W into 4r. But the 4ohm speaker should be of a moderate rather than severe load type.
