jacquesl said:Why is it so difficult to put transistors in series, like if you want it to be in a amp?
People have said by putting transistors in series is not that easy.
Can someone please explain that one to me please ?
What do you mean by 'series'?
If you mean like in darlington configuration,
it is not so difficult or bad.
And in circuits/amplifiers using negative global feedback
this is never any big problem.
Darlington configuration of 2 transistors.
http://www.hobbyprojects.com/junction_transistors/darlington_pair.html
HobbyProjects.com - Transistors Tutorials
lineup Quick and sometimes good Answer for you!
That is how the output stage of the swtpc 250 watt amp was, back in '78. edit:..(wired in series due to low voltage zistors)
Here's a partial. Q17, 19, 21, 23 are the neg rail zistors.
Q21 and Q23 are held to half the rail to output voltage by:
R34 and R36 divide the total (note the three diode drops also are included). Q13 holds the bases of q21 and q23 at half that voltage drop.
Q15 is the soa limiter, if the drop across r40 is too high, q15 reduces drive. r44 goes to output node, and lowers the clamp threshold when the output rail is further from q15, this limits negative current max when output is positive. Same happens with pos rail.
Those 200 ohmers do get hot..
Cheers, John
Cheers, John
That arrangement is called a ladder.
I have not seen it used much in audio, since transistirs >100v are easy to find.
I used to use them in 2,000V power supplies ( crudely 10 x 250V transistors in a ladder).
The problem is getting them to share the voltage equally, which wasres quite a bit of power in the base to base resistors.
cliff said:That arrangement is called a ladder.
I have not seen it used much in audio, since transistors >100v are easy to find.
The problem is getting them to share the voltage equally, which waste quite a bit of power in the base to base resistors.
Yes, no problem find high voltage transistors today.
Most of them REALLY HIGH were developed for Video =TV, use.
Very nice TO92 for moderate high voltage for audio are:
2N5551, NPN, 160 volt C-E ..... 2N5401, PNP, 150 volt Collector-Emitter
... and we have also also these TO92
MPSA42, NPN, 300 volt, 0.625 Watt .... MPSA92, PNP, 300 volt, 0.625 Watt
http://www.fairchildsemi.com/ds/MP/MPSA42.pdf
http://www.fairchildsemi.com/ds/MM/MMBTA92.pdf
MPSA42, NPN High Voltage Amplifier
This device is designed for application as a video output to
drive color CRT and other high voltage applications.
Spice Model
NPN (Is=34.9f Xti=3 Eg=1.11 Vaf=100 Bf=2.65K Ne=1.708 Ise=16.32p Ikf=23.79m Xtb=1.5 Br=9.769 Nc=2 Isc=0
Ikr=0 Rc=7 Cjc=14.23p Mjc=.5489 Vjc=.75 Fc=.5 Cje=49.62p Mje=.4136 Vje=.75 Tr=934.3p Tf=1.69n Itf=5
Vtf=20 Xtf=150 Rb=10)
MPSA92, PNP High Voltage Amplifier
This device is designed for high voltage driver applications.
Spice Model
PNP (Is=218.9f Xti=3 Eg=1.11 Vaf=100 Bf=99 Ne=1.307 Ise=218.9f Ikf=.2016 Xtb=1.5 Br=24.67 Nc=2 Isc=0
Ikr=0 Rc=7 Cjc=19.88p Mjc=.4876 Vjc=.75 Fc=.5 Cje=81.49p Mje=.3493 Vje=.75 Tr=516.9p Tf=1.395n Itf=1.5
Vtf=22 Xtf=270 Rb=10)
If we think TO126 capsule
(might be needed, Power= Volt x Current )
we have these 'video transistors'.
They are quite often used in Audio Amplifiers
MJE340, NPN, 300 volt, 20 Watt
MJE350, PNP, 300 volt, 20 Watt
Speaking of high voltage devices.
There are MOSFET N-CHANNEL, at least,
that can take extremely high voltages for very fast switching ... 700 Volt D-S and so
lineup
d3imlay said:Since the voltage across the xistors is cut in half their power dissipation is 1/4.
Neat trick!!
You are using V^2/R, but R is NOT the same for each device.
Power = V x I, for a given powe I = constant so W is 1/2, as you would expect.
here in Hungary a factory manufactured amps for PA usage with serial-quasicomplementary output stage. It was in the late 80's, and early 90's. From 200W to even 600W.
I've got the schematic (hand drawn) of the 250W model, it's called Castone CPA-500.
It uses Tesla KD502's (same as 2N3772) as final transistors. The drivers are BD139.
That amp is dirty cheap to rebuild, but it sounds really crappy...
- putting transistors in series
