who do you think has the best circuit simulator and why?
#2 | |
- OrCad are very big and good. - Eagle is FREE and not bad. If you consider it is all free. - EWB Electronics WorkBench MultiSim is very good, but not free. then there are several other free downloadable programs as well as commercial I do not know which is best, especially for AUDIO simulations. But there are members here, that would know just about anything you want to know. I use MultiSim, only because I managed to get a Free Copy. I got via file sharing ....... hmmm And I like it. Very much. I use MultiSim9. Will be interesting to hear what other think about BEST AUDIO Circuit simulator. What does MikeB say? What does he use? I know he is very good with this. Regards lineup
lineup |
#3 |
LTspice is the best by far. It's free and very fast. The only limitaiton is that it doesn't have a huge library of parts. In reality, this should not be a problem, because you can easily use any Psice compatible model.
#4 |
Drawing schematic will be "teriblely" easy if you use Orcad
Multisim8 do this badly. I don't know why this feature of Multisim still bad although its version is 8. . This feature of Orcad have been good since version 9.0. After developing for many years, Multisim is still bad at this. Perhaps this is a reason why Orcad is the best simulator Orcad 10.5 run simulation teriblely slowly FFT of LTSpice use logarithm-axis, while Orcad use volt-axis . Sometimes, I prefer logarithm -axis
Justice for Victims of Agent Orange http://www.petitiononline.com/AOVN/Thank all of you! |
#5 |
I'm using Multisim 8 from the EWB 8 program group.
It's quite good! |
#6 |
I have just simulated my amp by LTspice and Orcad 10. My amp ocssilate with Orcad but It is good with LTspice. I copied spice model from Orcad to LTpsice so both software use the same model.
Has anyone spice model of A1227 and C2987 ? I'm using these BJT. I use A1302 / C3281 for simulating Bye!
| DAT Simulator | jman 31 | Instruments and Amps | 4 | 1st February 2009 01:44 PM |
| Ultimate amp simulator | Wavebourn | Instruments and Amps | 5 | 28th October 2006 05:21 AM |
| Page generated in 0.10200 seconds (67.44% PHP - 32.56% MySQL) with 10 queries |
