Old 4th December 2006, 06:03 AM   #1
Nixie is offline Nixie  Canada
Banned
Default Active current source
http://www.tubecad.com/2006/12/blog0088.htm
Doesn't that active current source seem pretty similar to Pass' Aleph patent?
Old 4th December 2006, 06:36 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
The current source looks very basic to me. How does Mr. Pass' current source look like?
/Per-Anders (my first name) or P-A as my friends call me
Old 4th December 2006, 12:10 PM   #3
Banned
I'm talking about this one: "the current varies with the output swing, drawing the most current when the output swings down close to the negative rail voltage, and drawing the least current when the output swings close to the power supply rail voltage"
Old 4th December 2006, 07:11 PM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
It is what I always did: pushed crossover distortions to higher powers (A+C design), or avoided them completely using emitter, or source, or both followers, loaded by a constant current source that follows the output signal, "drawing the most current when the output swings down close to the negative rail voltage, and drawing the least current when the output swings close to the power supply rail voltage". I don't understand what is new in their design, and which "invention" are they going to protect by the patent?
It is the same cheating with fancy words, like similar British patent, about "Current Dumping that uses bridges".
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 4th December 2006, 07:17 PM   #5
Wavebourn's Avatar
Here is my example of what they are going to patent:
Old 4th December 2006, 07:21 PM   #6
Wavebourn's Avatar
..and here is again my example of crossover distortions shifted to less audible powers:
The question is, will they try to sue me if I decide to sell my projects that include what they patented after I designed them? Are publiucations on forums enough to protect me against their lawers?
Old 4th December 2006, 09:15 PM   #7
Wavebourn's Avatar
Also, removing crossover distortions from opamps, very old and good working trick... However, resistors don't provide a current that follows output signal, but anyway the current they provide shift bias so crossover distortions if ever exist are less audible than on zero power...
Old 4th December 2006, 09:31 PM   #8
Wavebourn's Avatar
...and, finally, complementary "Tango" pairs, when BJTs are biased in A class, results again in shifting crossover distortions to less audible powers.
(the example above uses unbiased version when powerful driver works in class A: http://www.diyaudio.com/forums/showt...44#post1072644 )
Alternative Active Current Source for Aleph-X ?? EUVL Pass Labs 17 8th February 2012 03:31 AM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 12:55 PM
Active Current Source for TDA1543 stefanobilliani Digital Source 17 12th November 2003 02:18 PM
Source follower electret mike -> use with current source? capslock Solid State 1 28th February 2003 12:54 PM
Active current source or power resistor? woody Everything Else 2 19th September 2002 03:33 AM
Page generated in 0.10212 seconds (73.74% PHP - 26.26% MySQL) with 10 queries
